Gauges don't work
Old Dec 3, 2012 | 02:40 PM
Thederrick's Avatar
Gauges don't work
I have a 1968 Oldsmobile 98 and none of the gauges on it work. The speedometer doesn't work, gas gauge doesn't work, and my clock doesn't work. If anyone can help me with this that would be amazing. Priority one is to fix the gas gauge because I ran out of gas the other day.
Thank You.
Old Dec 4, 2012 | 06:51 PM
m371961's Avatar
Speedo is mechanical and runs off of a cable. On my 65 cable runs from speedo to left frount wheel dust cover. If clock is getting 12 volts it is most likely stuck. I removed mine, took cover off of back, sprayed with wd and it started working. The first question on fuel guage is it staying on full or empty. If on full, check for ground wire at sender.
Old Dec 4, 2012 | 08:26 PM
steverw's Avatar
first and easiest thing to check is the sending unit on the tank i think
Old Dec 4, 2012 | 09:18 PM
Please note that this question was double posted to two different threads, and is already being answered here
lemoldsnut
Oct 4, 2025 07:40 PM
smkn600ctd
Dec 29, 2014 05:38 PM
Thederrick
Dec 4, 2012 10:19 AM
citcapp
Dec 14, 2009 11:10 AM
daverbmxer
May 30, 2006 05:35 PM
