Gauges don't work
Old December 3rd, 2012, 02:40 PM
Thederrick's Avatar
Gauges don't work
I have a 1968 Oldsmobile 98 and none of the gauges on it work. The speedometer doesn't work, gas gauge doesn't work, and my clock doesn't work. If anyone can help me with this that would be amazing. Priority one is to fix the gas gauge because I ran out of gas the other day.
Thank You.
Thederrick is offline
Old December 4th, 2012, 06:51 PM
m371961's Avatar
Speedo is mechanical and runs off of a cable. On my 65 cable runs from speedo to left frount wheel dust cover. If clock is getting 12 volts it is most likely stuck. I removed mine, took cover off of back, sprayed with wd and it started working. The first question on fuel guage is it staying on full or empty. If on full, check for ground wire at sender.
m371961 is offline
Old December 4th, 2012, 08:26 PM
steverw's Avatar
first and easiest thing to check is the sending unit on the tank i think
steverw is offline
Old December 4th, 2012, 09:18 PM
Please note that this question was double posted to two different threads, and is already being answered here
MDchanic is offline
lemoldsnut
October 19th, 2020 11:49 AM
smkn600ctd
December 29th, 2014 05:38 PM
Thederrick
December 4th, 2012 10:19 AM
citcapp
December 14th, 2009 11:10 AM
daverbmxer
May 30th, 2006 05:35 PM
Quick Reply: Gauges don't work
