Why 66-67 gas gauges don't work sometimes
Old Jul 28, 2015 | 06:03 PM
lemoldsnut's Avatar
I have seen many ask why a 66-67 gas gauge does not work. Other than the obvious sending unit. Oh and the ground wire at the sending unit being truely grounded. ( I always use those teethy washers on all grounds) Here is a possible cause. The plug in at the printed circuit can have broken prongs. I have seen this in almost every other one I take apart. I am sure a good person with a soldering gun can repair this. I was lucky to have a good printed circuit. I have also found that bypassing the plug works if you are not going to pull the dash. (see picture)
Only three wires feed the fuel gauge: 12volt keyed, ground , and the sender.
Pic 1 is the printed circuit plug with three prongs missing
Pic 2 is the plug in with three prongs in it
Pic 3 is a good printed circuit
Pic 4 is wires bypassing the plug in
Here is a few images of the prongs broken. and a good printed circuit plug in.
Hope this helps some who are trying to figure it out.
Larry
Old Jul 28, 2015 | 09:59 PM
cjsdad's Avatar
Excellent info! Thanks for that. It might explain why my fuel gauge worked for a moment after I repaired the ground, and then quit again. Part of the issue with mine was the previous owner had removed the fuel tank and managed to break the ground wire off the sending unit. Here are some pics of how I fixed that end. You can see in the first picture that the ground lug is almost indistinguishable from the rest of the surface rust. The second pic shows the rust scraped off a bit. Third pic shows the female connector that fits on the ground lug perfectly!
Old Jul 28, 2015 | 10:01 PM
young olds's Avatar
I've actually just recently started messing with my fuel gauge. I took the sender out cleaned it and confirmed it was operating properly and still doesn't work. I'm going to look into this on my car next time I mess with it
Old Jul 28, 2015 | 10:43 PM
Yellowstatue's Avatar
Broken pins can be repaired by using 2mm screws obtained from model shops. Insert screw through opposite side of cct. into broken pin. Try screws that are about 1/4 inch long.
Old Jul 29, 2015 | 07:39 AM
66-3X2 442's Avatar
DING DING DING We have a winner^^^^^^^^^^^^^^ I have been using #1 sheet metal screws for years to repair/tighten loose pins. If I have a board with completely broken off pins,I toss it and find another board.
Old Nov 6, 2018 | 09:19 AM
lemoldsnut's Avatar
Rocket Olds
you asked me about this thread and I just found it. hope it helps.
Larry
lemoldsnut@aol.com
541-815-4363
Old Nov 9, 2018 | 08:10 AM
young olds's Avatar
Glad this popped up, mine got loose again after a previous fix, I’ll have to try the screws.
Old Nov 9, 2018 | 09:32 AM
Tiberian Fiend's Avatar
Mine quit working because it needed to be lubricated. Same for the speedometer. Paid a speedometer shop $200 to learn that, so I thought I'd save someone else the money.
Old Nov 10, 2018 | 05:22 PM
mzbk2l's Avatar
Similar fix here: https://classicoldsmobile.com/forums...uit-board.html
Old Oct 19, 2020 | 11:49 AM
lemoldsnut's Avatar
Was just asked about this again. SO, thought I would post on it to put it back up on the top.
Hope it helps someone
Larry
Old Oct 4, 2025 | 12:19 PM
Joel's Avatar
Larry
Good info, thanks. In picture 4 with the wires bypassing the plug, can you please identify which function each wire is? That would help me with my testing. Thank you, Joel
Old Oct 4, 2025 | 07:06 PM
lemoldsnut's Avatar
As your sitting in the car looking forward. Bottom is ground, upper left is keyed 12 volt. Upper right is sending unit
Old Oct 4, 2025 | 07:40 PM
Joel's Avatar
Got it. I just tested by applying 12v+ to the upper left and the gauge now works!
Thank you!
jRoofgunner
Mar 14, 2018 06:43 AM
tgilligan
Jul 17, 2017 07:44 AM
flyingethan
Mar 25, 2015 07:03 PM
70 ctls
Feb 9, 2015 04:50 AM
IZAOLDS
Apr 10, 2011 05:04 AM
