PDA
View Full Version : 442
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12
  1. vin #
  2. Gen Light 71 olds 442 w30
  3. 69/70 Olds 442
  4. Need help buying 65 442
  5. Carb and distributor ID
  6. Trim tag and VIN numbers
  7. 1967 442 Vinyl Top Trim Clips
  8. 1970 w30
  9. 1967 442
  10. Backing up, hear clicking
  11. Spark plugs
  12. My 1970 W30 discussion thread
  13. 1967 442 A Pillar "Gap"
  14. 1966 442 E block
  15. 66 442 battery tray in trunk
  16. 66 OAI ducting clamps
  17. 1988 442 factory drag car
  18. 1966 POP decode
  19. 69 W-30 emblem placement location
  20. 4 speed dual gate in 72 442
  21. 1970 442 Advice
  22. Windshield
  23. 1971 442 w30
  24. W-30
  25. Red Fender Wells
  26. trunk splatter paint question
  27. 70 olds W-30 suspension question
  28. 1972 Cutlass 442 W30 Convertible Restoration Questions
  29. 69 442 not starting
  30. Searching for Provenance
  31. 66 442 heat riser block offs
  32. 67 442 thottle switch adjustment & carb rod adjustment
  33. 442 Tachometer
  34. 69 442 mufflers
  35. How far do exhaust trumpets stick out?
  36. 1970 W 30 no docs impact on resale
  37. hood insulation rubbing against power steering cap
  38. Firewall numbers
  39. ISO: 1968 442 sports coupe
  40. 1965 442 California built
  41. Window Trim (again) and Alternator Brackets
  42. Non ac pulleys for 71 442 w30
  43. 69 442 W29 Option
  44. Heater control valve
  45. 1967 Bottom of Hood Color
  46. 1967 Front/Rear Glass Clips and Studs
  47. Thoughts on this 1971 442
  48. Radiator and condenser installation
  49. What are these parts
  50. Looking to buy a 7040256 Carb
  51. Trumpet Tips
  52. Engine originality
  53. Package Tray Speakers
  54. Ancestry search for 70 442 convertible
  55. 70 442 - Fuel Tank Cover
  56. 68 cutlass/442 decklid question
  57. What is this part?
  58. Pics of 65 442 Engine Bay
  59. 68 442 dash pin stripe
  60. Decode a Trim Tag?
  61. 69 442 conv 4 Spd
  62. 1965 442 Exhaust question
  63. Stripes?
  64. Car Show Fact Sheet 1969 442 Convertible
  65. 70 W-30 current condition value.
  66. best gift for Olds fan?
  67. 1970 442 Cruise Control Servo
  68. 1965 442 Convertible exhaust manifold options
  69. Thoughts on this car for sale?
  70. 67 442 Kickdown switch - AGAIN
  71. How many knew about this one?
  72. Heat riser tube
  73. Muscle Car Museum 442
  74. 67 442 with 442 sluggish after sitting awhile
  75. 69 442 engine temp
  76. ‘65 442 Center Console - Which is correct?
  77. 65 442 400 cui engine valve seals
  78. color for hood hinges and underneath hood
  79. Searching for a 69 442
  80. 1976 442 carpet color
  81. 70-72 442 Quarter extension moldings
  82. Camshaft specs
  83. Mystery plug?
  84. 72 W30 Only Stamped W29 on Broadcast?
  85. 400 to 350 to 400
  86. Seeking Whereabouts of this Sterling Silver 1971 Oldsmobile 442 W-30 4-speed HT
  87. earliest built 1969 w30
  88. 1970 442 (W30?) Original Bill of Sale
  89. No Fuel, 69 442 running a 1970 455
  90. Hurst Shift Handle
  91. Brake Booster Questions
  92. Red 69 442 convertible remote mirror
  93. 68 442 4 speed positive battery cable routing
  94. "Roar" coming from the front of the engine.
  95. New to forum and Olds 442
  96. 1967 442 Headlight Bezel!!!
  97. How much is this 1970 Oldsmobile 442 worth?
  98. 69 Radiator ID??
  99. filler panels
  100. Setting timing with a vacuum guage
  101. Fuel pipe to carb issue
  102. 67 Olds 442 Radiator shroud
  103. Help estate value 1970 442 valuation
  104. 4 spoke steering wheel
  105. "67" 442 Quadrajet
  106. My 67 442 has the wrong bumper.
  107. 69 442 tailpipes
  108. 442 fender emblems 230722 230723
  109. New to me my next cruiser 70 442
  110. Fremont production numbers?
  111. 71 442 W30 Parts Car Quality Value
  112. 67 442 fuel pump (2 lines)
  113. 1966 Oldsmobile 442 Convertible ?
  114. 5.1” 72 350 water pump numbers
  115. 1969 442 - Change a Key tumbler in a cylinder
  116. Trying to figure out what I have. Can Someone give me any info about my 442?
  117. Is This A True 1967 442 Cowl Tag?
  118. 1970 Y74 442 Pace Car (Not Mine)
  119. 1969 442 W-30 - My father's Oldsmobile.
  120. Stuck in gear
  121. just plain sad :(
  122. 70 am radio
  123. 72 442 engine pictures
  124. Lic. Plate bracket
  125. 65 Cutlass 442 question
  126. Id cowl tag
  127. Rear deck lid trim on 69 442
  128. Fuel tank question
  129. Best Olds Parts Dealer
  130. Help me with the valuation of a Restomod 68 442
  131. 1966 442 tri-power
  132. Learning about my newly acquired 1970 442 W-30
  133. Rust where the front window and dashboard meet
  134. 1972 w-30 master cylinder question
  135. Fix for 1970 olds 442 w-30 running hot at hwy speeds.
  136. Cowl tag id
  137. Replacement tach
  138. 1969, 442
  139. A body column to floor shift
  140. Blue engine paint in a can
  141. 1968 442 w30 4 speed
  142. 1980 442 Exterior Production Questions
  143. W-27 rear end cover Olds 12 bolt?
  144. windshield washer jar 1970 442
  145. Headliner clip
  146. Need parts car or new project ? 65 Olds 442
  147. Vacuum line diagram
  148. Any differences between Vin-9 and Vin-Y carburetors
  149. 1970 w30 intake
  150. 1968 BOP Axle shaft question (non-c clip)
  151. Z Bar Rebuild
  152. 1977 Cutlass 442 Slant Nose Grilles Needed
  153. protect o plate question
  154. 1972 442 Trunk Trim Molding
  155. 1968 442 Intake question
  156. 71' 442
  157. 1970 442 jack question
  158. Decals
  159. Finally / '68 442 Restoration
  160. Well It's Gone
  161. Cowl weatherstripping '70 W30
  162. 1970-72, 4-speed back-drive linkage for Super T-10
  163. Speedo cable
  164. 1970 dome light lens question
  165. mark your calendars Feb. 3, 2021
  166. Help needed with clutch problem
  167. Filling Up ... and Out
  168. 1967 442 convertible. Throwing in the towel
  169. Choke trouble
  170. 1980 442 slim odds
  171. Body plate decode
  172. '70 Gold Stripe Paint Color - help needed to match
  173. Holley Sniper fuel injection
  174. 1969 442 cowl tag help
  175. Rattle Can Paint
  176. 1972 442
  177. 1969 442 W-30 Carb 7029254
  178. 67 442 Power Steering Fluid Level???
  179. Another timing question
  180. 1970 cutlass dual gate conversion
  181. 4 Speed Shift Ball Color
  182. Engine block ID
  183. HEI distributor vs Edelbrock
  184. 71 Olds 442 search price and thoughts please
  185. 442 gear ratios
  186. Help with decoding
  187. 442 values per year ranking.
  188. Is this a legit 1980 cutlass 442 w30 And what is it worth
  189. Secret to getting 70 442 convertable master window switch seated in plug
  190. Didn't Plan On It But Had To!!!!
  191. 1969, exhaust
  192. 1968 422 Hood question
  193. Sales brochures or reference material.
  194. Front windshield
  195. Is this the correct carb for my 442
  196. stock rear coil springs
  197. 1967 motor?
  198. 442, 400ci
  199. 442 oil leak
  200. Repicated Broadcast Card W30
  201. 1980 442 Option Question
  202. Happy Memorial Day & Gift Idea
  203. Type o gears
  204. A/C System Lubrication
  205. motor mount issue
  206. Engine VIN question
  207. 1969, 442
  208. 1969, 442
  209. 1969, 442
  210. Interesting Fixer Upper Tips
  211. Final Time
  212. 69 - 442#s mounting on fenders
  213. 1969, 442
  214. Production numbers for automatic 1967 442's
  215. 1969, 442
  216. 350 in a 442?
  217. Grill color 64 442
  218. 69 442 hood toung
  219. 1969, 442
  220. 1966/67 442 chambered tailpipes
  221. Shipping doc for 100 drivers seats 🤔
  222. Title for 442
  223. Pop/snapping sound!
  224. 1970 Cutlass 442 stripe stencil/strip kit
  225. Copies vs. Originals
  226. 442 buying advice.
  227. 1968 442 Year One 17" X 9" Super Stock SSII & 275s rear?
  228. 1969, 442
  229. What color oil filter ? 66 442
  230. Help!!!
  231. w30 stamp on broadcast card - location?
  232. What Parts BooK?
  233. 1970 w-30 validation
  234. 3.23 Ring and Pinion
  235. Turbo 400 won't kick down & 4 barrel won't open
  236. Speedo/Dash Lights
  237. W-25 hood foam seal question
  238. 71 442 convertible
  239. Loose 442 badge
  240. W-25 Hood report
  241. Windshield
  242. 70 442W30 a.t. VS W25
  243. 1970 Olds 442 W30
  244. Battery life
  245. Best source for bulk fuel lines?
  246. Center console build
  247. 1965 A/C -Heater Blower Motor
  248. My finished 70 W30
  249. 1971 paint code 67 "SIENNA" what color was it?
  250. 442
