66 442 battery tray in trunk
Old Jun 18, 2022 | 01:25 PM
randy442's Avatar
Can someone please tell me which holes were used to hold down the battery tray for relocation to trunk. I have the location dimensions as per the olds installation instructions and it says "Re-use battery mounting parts except as shown",...and it shows a battery sitting on tray...which doesn't show much. There are 6 holes in the tray that are possibilities. Also, the placement has the tray sitting right over an embossed ridge. Are spacers used to level the tray?
Old Jun 18, 2022 | 07:41 PM
Run to Rund's Avatar
The 6 page instruction set shows the tray to be on the flat to the right of the hump for differential clearance. Two nuts will be in the open, inboard of the frame, and the third will be over the hole in the frame crossmember at the center of the coil spring.
Old Jun 18, 2022 | 08:34 PM
randy442's Avatar
I’m not referring to the large center hump. There is a smaller sharper emboss running slightly diagonally either side of the hump. The pic was taken from back seat area facing rear. The black sharpie lines are the dimensions given in page 6 as referred. 5 1/2 from back of back seat and 5 1/4 to 5 3/8 from side of right wheel well. No amount of fudging is going to clear that emboss.
Old Jun 19, 2022 | 11:00 AM
randy442's Avatar
Ok, I crawled under the car and see exactly what you’re saying. Looks like I’ll be using spacers to keep it level.
thanks for reply
Old Jun 19, 2022 | 06:34 PM
I don't have an extra battery tray handy, to look at the underside. I remember it having bulges, etc. and not being flat. I have not needed spacers when it is positioned correctly, even though it goes over that rib.
Old Jun 19, 2022 | 06:40 PM
66-3X2 442's Avatar
Neither did mine but it's been so long ago.
Old Jun 19, 2022 | 07:10 PM
randy442's Avatar
It is the same battery tray as used up front, right ?
Old Jun 21, 2022 | 12:21 PM
I got a loose 67 if you need pics.
Old Jun 21, 2022 | 09:10 PM
randy442's Avatar
[QUOTE=Koda;1435186]I got a loose 67 if you need pics.[/QUOTE
yes that would be appreciated Koda
Old Jun 21, 2022 | 09:32 PM
Pretty sure that's a 67. Bought it as such.
Old Jun 22, 2022 | 10:16 AM
randy442's Avatar
Yep. Identical to 66
old dog
May 27, 2021 11:51 AM
stevengerard
Sep 14, 2014 08:01 AM
Olds442redberet
Dec 21, 2012 02:44 PM
at3reg98
Jul 18, 2012 02:11 PM
PKHHBN
Dec 17, 2011 02:58 PM
