Blue engine paint in a can
Hey guys,
Has anyone ever seen the blue big block engine paint in a can for brush application? I am looking to just freshen up a bit under the hood. The motor was painted and installed 8-9 years ago and needs some help at the exhaust ports.
Thanks!
Thanks!
Bill HIrsch has it. You will have to buy a quart though. Here is a link:
Auto Restoration Supplies for Classic Cars, Antique Cars, Exotic Cars - HirschAuto.com
It'll just burn right off again from the exhaust ports. Each manufacturer makes a very different blue color, and I've seen manufacturer's colors change over the years. So you need the same of whatever was originally used if you want any kind of a match.
@redoldsman Thank you for the link to Bill Hirsch
It probably will burn off again, I look at it as maintenance. Hopefully the color is close to what is on there.
