Type o gears
Old May 25, 2020 | 07:41 AM
oregontopcat's Avatar
Type o gears
Looking for a good set of 3:23 gears, anybody got a set? Also question, what rpm should I be turning with those gears. 70 442 with auto trans. Thanks
Old May 25, 2020 | 09:07 AM
Engine speed also depends upon the rear tire height. The same gear ratio (3.23:1 in your case) will translate to different engine speed depending upon the rear tire height. Taller tire = lower RPM and shorter tire = higher RPM.
Old May 25, 2020 | 10:55 AM
There are several online calculators you can download and use if you know the variables listed above. Here is a link to one.
Engine RPM / Engine Speed Calculator
https://www.crawlpedia.com/rpm_gear_calculator.htm
Old May 25, 2020 | 06:20 PM
Ken, you are running the same size tires and the same diff ratio, I am turning about 3500 at 60, that seems high to me, maybe my tach is off, what are you turning at 60? Thanks, Dave E
Old May 25, 2020 | 06:48 PM
Yeah, that is a bit high. My car used to turn 3400-3500 at 70 MPH with the short 245-60-14" tires. I don't recall the highway RPM with the 245-60-15" tires but on surface streets going to work it is around 2200 RPM @ 45-50 MPH.
goatwgn
Drivetrain/Differentials
Oct 7, 2021 08:04 PM
sbFALL63
Jan 10, 2016 01:04 PM
Rocket North
Jul 11, 2015 07:34 AM
busman442
Jun 30, 2013 05:44 AM
1970_442
May 18, 2011 01:19 PM
