Type "O" 3.23 gears.
Old Mar 13, 2014 | 03:57 PM
goatwgn's Avatar
Does anybody know where I can get a set of 3.23 gears for a 1970 Olds Type "O" rear end (with the 12 bolt cover and the 10 bolt differential inside)? I know I can get 3.42s and 3.90 gears. I would like to get a set of 3.23s if possible. Thanks.
Old Mar 13, 2014 | 04:52 PM
You would need to locate an original GM set. I don't remember any of the aftermarket companies making 3.23s.
So where can you get the 3.42 and 3.90 gears? I thought they were out of production.
Old Mar 13, 2014 | 05:07 PM
goatwgn's Avatar
A company called "Liberty Gear". They have the gears, the bearings, seals and crush sleeve, as well as Limited Slip differentials.
Old Mar 13, 2014 | 05:47 PM
oldsmobiledave's Avatar
3.23s
There are no aftermarket 3.23s & the OEM gears only work on the 3.08 / 3.23 carrier. Be sure you know exactly what you have & exactly what you need before you start spending money.
Old Mar 13, 2014 | 06:33 PM
goatwgn's Avatar
I have a 3.08 carrier. Installed 3.42 gears some time ago from Liberty gear. Want to step back a little. May go back to the 3.08s.
Old Mar 14, 2014 | 01:00 PM
The 3.08s may be a better choice if you want to "step back". I remember a few years ago I was considering going from 3.23 to 3.42 and someone pointed out that the difference was only ~6% so not really worth the bother. 3.08s would be ~10% change, which you might actually notice.
edit:
You may not have any other choice as Liberty's web site does not show 3.23 gears for the O-Type, only 3.42, 3.90, and 4.10:
http://www.libertygearandaxle.com/ca...M%208.5%20Olds
Old Mar 14, 2014 | 01:14 PM
more
The 3.42s 3.90 & 4.10s are the same Richmond gears that many vendors sell. Problem is no one has them in stock.
You went to 3.42s & now you want to go back? Just put a taller tire out back & you will lower the effective ratio to that of a 3.23. As pointed out swapping to a 3.23 from a 3.42 is a waste of time & money.
Old Mar 14, 2014 | 03:21 PM
BlackGold's Avatar
Not really fair to say 6% is a waste of time and money. If 3.23 is the perfect ratio for you, have at it. Some people are into subtle differences. Not that 6% is all that subtle. I'd like to get a 6% raise this year, and if I do, I'm not going to complain!
Several years ago I went from 3.23 to 3.90, largely because I thought 6% wasn't worth it. Many's a time I wish I had gone for 3.42 instead. The 3.90s are fun on the track, but the engine's got enough torque that 3.42 would be plenty fun around town -- and much better on the highway.
I just wish Oldsmobile had done a 3.55, 3.64, or 3.73.
Old Mar 14, 2014 | 04:15 PM
goatwgn's Avatar
Do any of you all have an opinion on luck with using used gearsets?
Old Mar 15, 2014 | 03:11 AM
507OLDS's Avatar
The drivetrain vendors still list the Richmond gears for the O-axle,but you will find that ALL of them are out of stock.
I have a set of GM 3:23's that I would be willing to work some sort of trade for your 3:42's.
Old Oct 6, 2021 | 07:59 PM
oldsmobuser's Avatar
Do you still have your 3.23 gears? I know this post is a little old. Thanks.
Old Oct 7, 2021 | 08:04 PM
Funkwagon455's Avatar
I haven’t seen posts from Brian for quite a while. You might be better to pm member Monza. He is still active here.
airvegas
Jul 12, 2015 07:38 AM
val1550
May 13, 2014 02:32 PM
L77F85
Drivetrain/Differentials
16
Nov 29, 2013 06:19 AM
zbarrow
Mar 6, 2013 06:05 PM
goatwgn
Dec 28, 2012 08:28 AM
