1968 BOP Axle shaft question (non-c clip)
Old Dec 23, 2020 | 08:47 AM
rippinbyu's Avatar
Looking to do a disk break in the rear and pull the rear Axle shaft out to replace the bearings, seals, and update with longer Moroso wheel studs. Does anyone know if the "inner retainer" or "inner axle bearing lock ring" is reusable? Rockauto doesn't show a replacement part for this and the bearings don't show that it's included. Fusick wants $48.50 for each bearing however appears to come with the inner retainer for the bearing. ​​​​​​​
Old Dec 23, 2020 | 09:31 AM
The retainer should come with the new bearing. The early O-Type sealed bearing is RW507C and the seal is 8594S.
The National RW507C bearing is $24 at O'Reilly Auto Parts. My local store shows to have it in stock:
https://www.oreillyauto.com/detail/b...w507cr/2554210
The national 8594S seal is $11 at O'Reilly Auto.
https://www.oreillyauto.com/detail/b.../8594s/2552428
It usually gets destroyed when the retainer is removed.
Old Dec 23, 2020 | 10:50 AM
rippinbyu's Avatar
thank you!!!
slade69
Drivetrain/Differentials
Jan 16, 2020 03:35 PM
chadrickle
Apr 3, 2015 09:21 PM
72hurst
Apr 21, 2014 04:34 PM
Flye
Jul 30, 2009 10:24 AM
Bunser
Apr 21, 2008 03:12 AM
