Gen Light 71 olds 442 w30
Old Jul 30, 2022 | 02:25 PM
Uticaolds442's Avatar
everything was fine...drove back from a car show today with my 71 olds 442 w30...had about 1 hour drive. all good. went to shutoff and the car choked itself off when i turned the key off...instead of a normal turn off. So I tried starting it back up and had to turn it hard for a bit, then pump gas to get it rough starting...then the gen light came on??
Took it for a ride and it runs fine, starts fine, but the light is still on???
I am not that mechanical...but welcoming thoughts.
Old Jul 30, 2022 | 02:50 PM
You need to measure the voltage at the battery with the engine running, should be around 14.5 ish.
Old Jul 30, 2022 | 03:24 PM
Sugar Bear's Avatar
Unplug the alternator and start the car, if the light extinguishes the alternator is bad. Time for a rebuild. If your alternator is original DO NOT exchange it, get it rebuilt.
Good luck!!!
Old Jul 31, 2022 | 07:50 AM
Warren Seale's Avatar
The alternator is very easy to rebuild especially if the bearings do not have to be replaced. Kits are available and are not expensive.
BSiegPaint
Aug 30, 2021 01:46 PM
kevdog442
Feb 24, 2021 04:24 PM
dave marki
Jun 5, 2017 10:18 PM
71 Cutlass Ragtop
Dec 27, 2013 05:55 PM
jpaulwhite
Sep 28, 2010 04:24 PM
