1972 442 Trunk Trim Molding
Old Dec 10, 2020 | 05:33 PM
postsedan's Avatar
I am currently restoring a 1972 V Code 442 4 Speed.
Does anyone reproduce a good rear trunk trim molding set.....or is this an NOS item only?
Thank you,
Dan
Old Dec 10, 2020 | 07:37 PM
70Post's Avatar
Dan - I assume you're referring to the THREE PIECE molding set that runs along the bottom edge of the trunklid.
There seem to be plenty of nice used sets out there and Fusick Automotive sells a repro three piece set for $199 (note: I can't attest to the quality or exactness of the repros as I've never had a repro set in my hands).
What you have to be VERY CAREFUL of on used moldings is some dings will basically be impossible to remove depending on where they're located on the molding. You really can't get behind any ding (to tap out or push out the ding) that is on the outer face of the moldings (the "face" being what you see from the back of the car when the trunklid is shut).
I may have a nice original set that's already restored but I'd have to check my inventory here first to make sure.
Old Dec 10, 2020 | 07:52 PM
vCode442's Avatar
Vincit qui se vincit
Hi Dan I did a quick Google search as well as eBay, and the usual suspects all popped up selling a three piece molding set for your trunk. Fusick, The Parts Place, Tamraz - I also can’t speak to their quality but have purchased parts from all three and tend to lean towards Fusick.
More importantly, please post some photos! We all know how rare a V code 442 is so please share, and best of luck with your restoration.
Old Dec 11, 2020 | 04:54 AM
postsedan's Avatar
Patton,
Yes the 3 piece molding rear trunk molding. You are correct.... the one on this '72 442 is too damaged to repair.
I will send you a text....later today.
Vcode442,
Will do.
* Anyone else have any knowledge with Fusick rear truck moldings....how they fit and look?
Dan
Old Dec 11, 2020 | 09:45 AM
70Post's Avatar
Dan - Sent you a PM regarding text and email.
Thanks,
Patton
Old Dec 11, 2020 | 01:05 PM
Ap6954's Avatar
Originally Posted by postsedan
Patton,
Vcode442,
Will do.
Dan
I bought the Fusick moulding. I needed just the long piece for the trunk lid and it came as the 3 piece kit. I would say it fit pretty darn good. I usually avoid repop parts but this one fit well. Even the ends that overlap fit pretty good IMO.
Old Dec 11, 2020 | 04:57 PM
postsedan's Avatar
Ap6954,
Thank you....I appreciate the tip.
Dan
Billyaxe
Mar 8, 2022 12:07 PM
dougmbrown
Sep 29, 2014 03:26 PM
dnmfranco
Jul 14, 2013 08:59 PM
crd3907
May 27, 2012 03:33 PM
Steve Wike
Body work
May 17, 2011 08:47 PM
