65 Cutlass 442 question
Old Apr 4, 2021 | 09:16 AM
jerry63's Avatar
Hello, When you check to see if a 65 442 is a numbers matching car, what are you looking for. Thanks.
Old Apr 4, 2021 | 09:26 AM
66SportCoupe's Avatar
Engine and transmission numbers must match POP card. Also must have a 4V on data plate (won't have if a Fremont Calif built car) the rear should have boxed control arms and rear sway bay also. I might be missing a few other things.
Old Apr 4, 2021 | 10:41 AM
stan 65 cutlass's Avatar
go to 442bro.com and click is it a 442, depending where it was built there are a few differences, good luck, also w29.net is 65 only as well
Old Apr 4, 2021 | 11:14 AM
To clarify, there are no numbers that "match" on a 1965 Olds. Oldsmobile did not start stamping the block and trans with a VIN derivative stamp that matches the VIN until the 1968 model year. As noted above, Olds stamped an engine unit number on the front of the passenger side head and a trans unit number on the case. These are unrelated to the VIN, but if the Protect-O-Plate for that car is available, it will have the VIN and those unit numbers in one place. Of course, all this proves is that one cylinder head and the trans case are original. My 1967 Delta 88 is "numbers matching" despite having a later 455 short block and one head replaced. The only original part of the engine is the one head with the unit number on it.
I've found that most people who claim to have a "numbers matching" car actually have no idea what that means. On a 1967-older Olds, I start by asking "can you show me the numbers that 'match'?"
Old Apr 4, 2021 | 11:39 AM
To them, the term means that they believe the engine and drivetrain to be original to the car, although they have no way of proving it.
Old Apr 4, 2021 | 02:44 PM
Yeah, except for the ad that I saw for a set of "numbers matching" wheels. (I'm not making this up)
Or the "numbers matching engine" for sale that isn't attached to a car.
Should I go on?
Old Apr 5, 2021 | 10:22 AM
jerry63's Avatar
Thanks everyone for responding, you have answered all of my questions, Stay safe.
OLE442
Sep 18, 2019 05:29 PM
BoughtCutlass1971
Mar 21, 2016 11:47 AM
REDJET
Aug 30, 2013 10:25 AM
cogaritis
Aug 7, 2009 01:43 PM
joe_padavano
Jan 21, 2009 07:56 AM
