W-27 rear end cover Olds 12 bolt?
Old Jan 12, 2021 | 07:15 PM
rippinbyu's Avatar
I just received 12 Bolt Oldsmobile W-27 rear end cover for my 1968 442. None of the bolt holes line up....wondering if the Parts Place sent me the Chevy 12-bolt C clip one?
The part is case with numbers 406785 on outside...not sure if Olds 10/12 and Chevy 12 bolt all had this number on the reproductions? I'm assuming the 70 W-27 cover will work on the 68 Olds 12 bolt?
Chad
Old Jan 13, 2021 | 04:07 AM
JohnnyBs68S's Avatar
Sounds like they sent you the Chevy cover. I have an aftermarket W27 cover on my '68 Type-O rear (can't remember where I sourced it from). Are you sure your rear is a Type-O and hasn't been swapped w/ a Chevy 12-bolt (or is it a Canadian car)?
Old Jan 13, 2021 | 10:45 AM
rippinbyu's Avatar
Yeah pretty positive...I have the axle pulled apartment and it has pressed in bearing and not C clips. Cover is also the "O" Oldsmobile style.
I'll check with them. Thanks!
Jabenge
Feb 12, 2020 07:01 AM
Vader
Jun 11, 2014 01:19 PM
willcynn
Drivetrain/Differentials
Dec 8, 2012 04:03 PM
camdon454
Nov 9, 2012 08:53 AM
johnnybondo
Feb 12, 2008 11:13 AM
