Vacuum line diagram
Your call on if you want to use ported vs manifold vacuum for the advance. Ported comes off the port on the carb, otherwise use a manifold tap into one of the runners. Obviously power brakes comes off a runner at the back of the intake if you have PB.
If the car isn't stock, we can't know that unless you tell us. The OEM carb wasn't vacuum secondary. What else isn't stock? Hint: a photo goes a long way.
Yeah, but why bother? The car has no vacuum requirements other than distributor advance and PCV, which appears to be hooked up. It's totally aftermarket, so the stock ported vacuum source for advance is irrelevant. I don't know what additional info the OP expects to get or needs for this.
pmgriphone
Oct 18, 2018 08:36 AM
