Vacuum line diagram
Old Dec 28, 2020 | 11:30 AM
Ttnc's Avatar
Vacuum line diagram
Have a 66 442 with 400 engine. I need to find a diagram for the engine to carburetor vacuum lines. Car has 4 speed, no heat and no air.
installing 750 holley single fuel inlet.
Old Dec 28, 2020 | 11:55 AM
So the only vacuum line is manifold vacuum to the distributor advance can.
Old Dec 28, 2020 | 12:35 PM
Ttnc's Avatar
So none to the carb itself?
Old Dec 28, 2020 | 01:08 PM
Your call on if you want to use ported vs manifold vacuum for the advance. Ported comes off the port on the carb, otherwise use a manifold tap into one of the runners. Obviously power brakes comes off a runner at the back of the intake if you have PB.
Old Dec 29, 2020 | 05:47 AM
Ttnc's Avatar
Vacuum secondary on this. If I put a port in the intake where do I plug the other end into. Just checked and there are no lines coming from or going to the distributor.
thanks for your help.
Tony
Old Dec 29, 2020 | 05:49 AM
Tony
If the car isn't stock, we can't know that unless you tell us. The OEM carb wasn't vacuum secondary. What else isn't stock? Hint: a photo goes a long way.
Old Dec 29, 2020 | 08:01 AM
Ttnc's Avatar
400 w/4bbl and 4 speed. No air, no heat, no power brake
Old Dec 29, 2020 | 08:29 AM
I suggest you REMOVE the air cleaner and take another picture.
Yeah, but why bother? The car has no vacuum requirements other than distributor advance and PCV, which appears to be hooked up. It's totally aftermarket, so the stock ported vacuum source for advance is irrelevant. I don't know what additional info the OP expects to get or needs for this.
pmgriphone
Oct 18, 2018 08:36 AM
377rick
Jun 19, 2018 06:38 PM
gtdrvr
May 7, 2011 09:46 AM
54olds
Aug 7, 2008 12:20 AM
68ragtop
Jun 29, 2008 06:43 AM
