Trumpet Tips
Old Jan 18, 2022 | 06:59 PM
Crimson@69442's Avatar
Trumpet Tips
On a 68 442 were exhaust tips welded on or clamped from the factory?
Old Jan 18, 2022 | 08:13 PM
BackInTheGame's Avatar
Mine were welded. Looked original, but I'm the 3rd or 4th owner so I couldn't swear they came that way.
Old Jan 19, 2022 | 04:46 AM
rallyredw31's Avatar
welded 100%
Old Jan 19, 2022 | 07:18 AM
Huh. Mine were slip-fit when I got the car, but welded them when I went from 2" to 2.25" tailpipe.
Car is 53 years old, though.
Old Jan 19, 2022 | 07:25 AM
Factory was 2.25". My trumpets were slip-fit, then tack-welded.
Old Jan 19, 2022 | 08:43 AM
The factory tail pipe was 2". The tips were straight not ballooned like todays aftermarkets. they slipped into the pipe and were spot welded. On originals I have seen 2-3 welds on each. All GM A body tails were 2" 68-71. That goes for Chevelle's, 442's, Buick GS, and GTO's.
Old Jan 19, 2022 | 08:51 AM
Interesting. Thanks for that. I could have sworn I saw documentation of 2.25" OD pipes from the manifold back. I'll start digging to see if I can find that source.
Old Jan 19, 2022 | 09:02 AM
The factory muffler has a 2" outlet.
The only A-body that I've found with factory 2.25" tailpipes was the GTO. In the 1970s, before the large diameter aftermarket tailpipes were available, I would use those GTO pipes on my Oldsmobiles. At the time I was running the Walker Turbo mufflers with 2.5" inlet and outlet, and would need a 2.5 to 2.25 adapter at the outlet.
Old Jan 19, 2022 | 09:17 AM
Thanks, Joe. Thanks, too, rallyredw31. I've been wrong before! I wonder where I got that 2.25"...
Old Jan 19, 2022 | 11:15 AM
Yellowstatue's Avatar
The factory left down pipe was 2 1/4" from the manifold to the muffler where it was swaged down to 2" to fit the muffler. I have NOS tailpipes 404665-6 with welded tips.
Old Jan 19, 2022 | 12:55 PM
11971four4two's Avatar
MOTORHEAD
THE New Old Stock GM tailpipes I had , 1966 and 1971 had the tips from factory welded on
kansjfr
Jul 31, 2014 10:49 PM
kansjfr
Jul 14, 2014 09:13 PM
1968ragtop
Dec 7, 2011 07:00 PM
1971 Olds 442
Dec 7, 2011 06:28 PM
esisson
Jun 12, 2008 05:52 PM
