Stuck in gear
Old Apr 18, 2021 | 09:58 AM
ckh2399's Avatar
Stuck in gear
I just want to start off by saying I'm not super knowledge about cars, but I recently bought my deceased father's 1969 olds 442 that's on a cutlass body from my mother. It runs and I had it transported from NJ to MD and I'm in the process of getting it to a mechanic to see what it needs.
Long story short the car was able to go into reverse to get off the truck and went into gear fine for the quarter of a mile trip home and didn't have an issues with the drive. The next day I went to take it out and it seems like it is stuck in gear. The floor selector moves to the different positions as if it where changing gears, but the car will only move forward even when it's supposed to be in park or reverse. When I do drive it it seems like it just stays in a low gear. I only drove it around my development so didn't go over 20 mph.
Any idea of what might be going on?
Old Apr 18, 2021 | 11:04 AM
danktx's Avatar
I assume you have an automatic transmission. I would think that the shifter cable is broken or has become disconnected from the transmission.
Here is something to try, if your car still has the linkage that locks the trans in park when the key is in OFF you can turn the portion of the column that is between the dash and the turn signal lever. If you can turn it and feel detents you will be changing gears at the transmission. Turned all the way to the left is park, then 1 click to the right is reverse then neutral, then drive. The sleeve on the column moves just like your car has a column shift. I had to do this once many years ago to a 70 GTO. If the transmission lock linkage was removed this will not work.
Old Apr 20, 2021 | 08:43 AM
ckh2399's Avatar
Thank you. It was in fact the shifter cable that was broken and not letting it change positions.
Old Apr 20, 2021 | 10:09 AM
danktx's Avatar
When I had the problem with the GTO, I had broken the ground strap between the engine and body so the shift cable was functioning as a ground strap and it melted the plastic in the shift cable and jammed it up. Make sure you check a ground is connected or add a ground strap between the body and engine to prevent the cable from causing problems in the future. Good luck with your car.
Bfg
Jan 14, 2020 12:53 AM
4SPEED67
Feb 21, 2018 05:41 PM
chip-powell
Jun 7, 2016 05:54 AM
quentinnw2
Dec 11, 2013 08:50 PM
crazy'boutOlds
Jan 23, 2007 03:10 PM
