PDA
View Full Version : Transmission and Driveline
Pages : [1] 2 3
  1. 200r4 finally awaited
  2. Looking for options for TH350C repair/replacement
  3. rear disc brakes
  4. 72 Cutlass
  5. 200-4r shifting issues
  6. New guy with M21 shifter question
  7. Removal of Hurst Shifter from M20, in 1972 Cutlass
  8. 1931 Olds transmission tail shaft seal
  9. Tremec TKX swap Have you done one?
  10. When to use low vacuum modulator on TH400?
  11. Shifter ball size
  12. Kris Delta88 1969 LSD/Positraction
  13. 4 speed linkage diagram
  14. '66 Cutlass switch pitch Q
  15. 1967 Cutlass 4 speed hump
  16. Where to purchase a hydra matic.
  17. His n hers swap from column shift
  18. 4 speed column plate dimensions
  19. Powerglide PSA
  20. Turbo 400 cooler line route??
  21. Correct 4 speed shifter/ 67 Cutlass
  22. 455 flywheel questions
  23. Flexplate for an E Block 400 wont fit the crank bolt holes
  24. Transmission Coolant line ideas???? Repair
  25. Transmission Rebuild Recommendations S.FLA
  26. Transmission linkage
  27. 8.5 10 Bolt Parts Needed
  28. Correct Speedo gear for 3:23 with turbo 400 70 442
  29. Engine /trans mounts? Can't hold shifter in 1st...
  30. 67 442 Driveshaft questions- paint, stripes etc
  31. 73 Hurst/Olds Trans Cooler Lines Leak at Radiator
  32. '73 Custom Cruiser cruise control delete speedo cable
  33. GM vs Allison filter for THM400
  34. Why is my kickdown cable so short?
  35. 455 Flex plate for a 2004R
  36. Type O Pinion Yoke?
  37. 90 degree speedo adapter
  38. Bushings - shift linkage
  39. Help with a clutch
  40. Jetaway rebuild
  41. Bouncy speedometer 1978 Delta 88
  42. Is my Switch Pitch TH400 correct for my 67 442?
  43. Solenoid 400 turbo 1971 442
  44. Leaky trans cable / coupler and pan help!
  45. rear end ratio advice
  46. new guy here. 65 olds f85 driveline issues (trans/engine stalll)
  47. Th350 trans
  48. Type O Differential Bearings
  49. Trans rear decode 71 442 convertible
  50. Jetaway transmission leak
  51. 1965 f85 st300 v6
  52. Reversing uphill
  53. Slim Jim leaks
  54. Cam Thrust Button 66 442 400 ci
  55. Ring and pinion for a 402227
  56. '57 vs '56 Jetaway
  57. HELP! I cant put the 1-2 accumulator cap back on
  58. 73’ omega won’t shift into second gear (automatic)
  59. Looking for a reputable 200-R4
  60. Trans tag and trans vin info
  61. Dearborn 3 speed - Ford toplaoder - Hurst Shifter
  62. 394 trans adapter
  63. Flexpate install /69 455
  64. 1970-72 Dual gate shifter refresh
  65. 1957 Olds 88 371 to 200-4R Swap
  66. 2004R parts supplier needed
  67. schematic 1979 hurst shifter linkage
  68. 1951 Olds 88 won’t shift into 2nd
  69. U-Joint part number for stock 1966 Cutlass Sports Coupe
  70. 1969 442 that someone swapped in a 2.56 R2 axle. What are my options?
  71. Trying to Understand and Eliminate TCS
  72. 1969 442 Transmission Removal
  73. Transmission Fluid
  74. 1970 Cutlass Supreme Ring Gear Bolt Torque
  75. 200r4 to th400 swap 84 olds 98
  76. Slim Jim no D condition.
  77. 1967 442 shifter
  78. Slim Jim has left the chat
  79. Unknown rearend
  80. TH350 Speedometer Housing wire attached - identify
  81. Tracking down a strange rattle sound.
  82. VSS location on a 71 Cutlass Supreme
  83. 1968 Delta 88 Posi Upgrade
  84. Kickdown and Switch Pitch Solenoid removal and manual replacement in ST-300 Jetaway
  85. 1949 Series 88 - Column shifter slipping out of Neutral
  86. 1955 hydromatic help!
  87. Hydra-Matic missing front band adjuster
  88. Transmission cooling lines with headers
  89. Th350 simple question
  90. Question about 1968 Toronado transmission
  91. Front pump reinstall isn't going in
  92. Please help. Where is the tranny dipstick
  93. 200r4 lockup
  94. TH350 downshift cable firewall holes
  95. Column linkage bushing
  96. Chattering Clutch
  97. Borg Warner ST 10 shifter linkage kit
  98. Driveshaft Removal for a Pinion Seal Leak
  99. Correct Bell Housing
  100. New Hughes 25HD BPO
  101. leaking speedo cable at trans
  102. Jetstar 88 axle
  103. 1972 Cutlas shift linkage lock out
  104. Which Speedo Adapter?
  105. TC gap ?
  106. Transmission lines
  107. Kickdown cable
  108. Trying to I.D. my transmission
  109. 1964 "Slim Jim" to Manual Conversion
  110. 1963 Oldsmobile Dynamic 88 Tranny Help
  111. Hydra Matic Transmission
  112. The best overdrive?
  113. Kickdown switch on 71 442...
  114. 66 olds switch pitch 400 rebuilder in Northern California
  115. 1972 Cutlass - Broke Differential
  116. Pinion Angle Issue
  117. Severe whobble of flexplate and torque converter!
  118. 69&70 rear end
  119. 66 442 - Automatic to 4 speed Conversion
  120. Leak from Yoke?
  121. Shift issues after header install.
  122. '72 98 with 455 needs new transmission lines
  123. 1966 Delta 88 Switch Pitch transmission
  124. Rear End Swap for a 1978 Delta 88
  125. 67 kick down
  126. Toro diff video
  127. Need help with Muncie VIN
  128. TH425 Transmission Oil Problems
  129. Torque converter stall olds 98
  130. How much front to rear play should a driveshaft have?
  131. Olds 1971 442-TH400
  132. Trans identification
  133. Transmission and pinion offset
  134. Engine and transmission angle too steep
  135. 1969 Cutlass -Column to Floor shifter
  136. Yet another pilot bushing thread
  137. How to "undo" a shift kit?
  138. A body Intermediate Shaft and Coupling repair
  139. 98 Starfire Holiday Coupe Trans Oil
  140. 1964 Axle flange
  141. '65 clutch pedal & linkage
  142. 455 flex plate
  143. 350 BOP or 350 GM
  144. 1964 Olds Cutlass Versus 1964 Chevelle Rear End
  145. 1970 Dual Gate Shifter Cable
  146. 65 400 pilot bearing
  147. Transmission replacement
  148. Demon carburetor with TH350 help needed
  149. 10 bolt gm?
  150. Weekend junkyard th350 search, need help
  151. Automatic transmission
  152. Kick Down Conversion for 67 442
  153. Differential shops
  154. Jetaway wont shift from second to third gear
  155. Pinion center line offset??
  156. TH400 on 7000+ RPM
  157. Need to shift rearend over 1/2"
  158. Is there a spec for clutch fork pivot ball?
  159. Clutch not disengaging
  160. 1961 Olds Starfire Transmission Swap
  161. Harmonic Balancer 1962 F85
  162. Ronnie
  163. 1966 442 Auto shifter
  164. 69 cutlass 350, modulator pipe
  165. clutch fork length
  166. clutch fork length
  167. TH400 Questions 77 Cutlass
  168. Torque converter hub diameter
  169. 1976 K20 TH350 no 3rd gear when accelerating
  170. 1953 Olds Automatic Transmission crossmembers
  171. Driveshaft only slides in 3/4 inch on TH350
  172. 69 Cutlass S Turbo 350 fluid fill
  173. Hurst Lightning Rod Shifters
  174. TH350 / 455 / stock diff / converter stall speed help
  175. Driveline vibration in reverse
  176. where to get axle bearings and seals for type O 70 vista cruiser?
  177. Back drive linkage clearance
  178. Sourcing parts for 200r4
  179. TH350 Trans cooler thread size on case
  180. Another Detent Question -
  181. Detent Switch
  182. What kind of rear
  183. T-400 Modulator Tubing Size?
  184. 63 caddy jetaway issues
  185. 1995 4T60e, Help.
  186. Flywheel & clutch help
  187. 1968 4-4-2
  188. Won’t stay in Park
  189. Type o axle endplay
  190. Valve body removal? 1963 slim Jim
  191. Ratchet Shifter
  192. Torque converters? Chevy vs BOP
  193. Th350 vin
  194. Throttle valve 54 88
  195. !2 Bolt TM Differential
  196. 1927 Oldsmobile Model 30e - Trans & Diff Fluid
  197. 200r4 ecm delete question
  198. 55 Olds hydramatic service/rebuild
  199. Axle bearing needed
  200. 72 Cutlass S can anyone easily tell me what rear end is this?
  201. TH-400 Shuddering in 1st
  202. Shifter Handle
  203. Hydraulic Throwout Bearing Installation
  204. Help?
  205. 1967 442 clutch return spring
  206. Rear End tag
  207. 455 Pilot Bearing Help!
  208. Why cruise at 3000 RPM
  209. TH350 Speedometer gear seal
  210. Hurst lightning rod shifter parts
  211. first gear starts in Hydramatics
  212. Help ID my 12 bolt
  213. Need advice for th425 in a 77 gmc RV
  214. reverse light 66 cutlass
  215. 1970 442 drive shaft lengths from the factory.
  216. Rearend ID help
  217. 58 dynamic 88 auto
  218. Differential - Reverse only?
  219. T50 bell housing confirmation needed please.
  220. 200-4r Rebuild thread by Dr Dan???
  221. Unnecessary cruise control parts?
  222. Strange Tranny Leak
  223. th350 trans, replace the jetaway.
  224. Muncie 4 speed
  225. Speedo off
  226. Tired of steering box leak
  227. Strange Leak
  228. transmission noise
  229. How hard is the th350 to 200r4 swap?
  230. 200-4r oil pump bolts leak
  231. help with dual gate shift cable
  232. power steering high pressure hose
  233. POP noise and a massive tranny fluid leak
  234. Shudders in reverse when cold
  235. Transmission leak
  236. Gearing questions
  237. Diff leak
  238. hydraulic clutch conversion kit
  239. 67 Cutlass - 2 speed ST300 question
  240. ‘70 Cutlass Supreme - Rear Improvements
  241. Posi unit I’d please
  242. Speedometer no longer working - 68 Olds DELMONT 88
  243. 1969 Cutlass 442 - Floor Shifter won't go into "P" Park
  244. Recommendations for Hydraulic clutch conversion
  245. Tourqe converter question
  246. Stick shift out of alignment??
  247. 1964 Oldsmobile Hydra-Matic Bell Crank
  248. 1970 Olds 98 Acceleration Vibration
  249. Toronado 1966 Drive Axle problems
  250. Transmission kick down plug
