Ratchet Shifter
Old Sep 8, 2021 | 10:50 AM
James71Cutlass's Avatar
Ratchet Shifter
Looking to put one into my '71 Cutlass S Car. I have a 200r4 that's going to be going into it as well. Should I be looking at a B&M or Hurst shifter? This is just a cruising car, so I don't want to be paying too much for one.
Thanks.
Old Sep 8, 2021 | 10:57 AM
gs72's Avatar
72Cutlass S
if you have a factory console and shifter you might want to look into this. Looks factory and is a lot more affordable.
https://classicoldsmobile.com/forums...7/#post1362990
Old Sep 8, 2021 | 11:01 AM
Thank you. I'll take a look. My factory shifter is on the steering column. I would like to make it look as factory as possible.
Old Sep 8, 2021 | 11:55 AM
gs72's Avatar
72Cutlass S
You need a factory floor shifter for the new detent plate to work.
Old Sep 8, 2021 | 12:00 PM
If it's just a cruiser, why would you need a ratchet shifter?
Old Sep 8, 2021 | 12:52 PM
Or even a floor shifter? you can use the factory column shifter, just won't be able to manually shift to 1st, which is a don't care for a cruiser.
Old Sep 8, 2021 | 01:03 PM
I like to get on it from time to time. A friend has one on his Duster another oh his 57 Chevy. I just like the way they feel and work. By cruiser, I mean I don’t race it at the track.
Old Sep 8, 2021 | 04:07 PM
So are you planning to install a factory console, or just a stand-alone floor shifter? With the factory console and shifter, you can look al original but have a 4 speed slap shifter.
Old Sep 8, 2021 | 07:18 PM
gs72's Avatar
72Cutlass S
I put this modified detent plate from Dan Janes in my factory console shifter and it has been one of the best upgrades I have done to my car thus far. I highly recommend it to anyone considering an aftermarket shifter.
Old Sep 9, 2021 | 05:49 AM
If I can find a factory console I'll go that route.
Old Sep 9, 2021 | 06:55 AM
Inline's Avatar
Rstchet shifter at street car is by far the worst mod money and usability wise ive done.
Old Sep 9, 2021 | 06:59 AM
Why didn't you like it? As I mentioned before two of my friends have it in their cars and love it. I live in Canada so I get 5 to 6 months a year of driving. Maybe put on a few thousand miles a year on the car.
Old Sep 9, 2021 | 03:15 PM
RetroRanger's Avatar
72 Olds CS
Yeah its fun to bang out a no worries shift, VS hitting nuetral on the factory shifter. (with no detent plate)
I think the factory shifter and console would look better than the Z gate or other similar mini console type shifters
That said the factory console shifter route is likely more expensive, i would be tempted to either retrofit and a newr car console or make a console and fit the hurst or BM shifter to that.
do you have bucket seats in the car ?
Old Sep 9, 2021 | 04:50 PM
gs72's Avatar
72Cutlass S
Or you can go this route if you don't have a console.
https://www.kilduffmachine.com
Old Sep 9, 2021 | 11:47 PM
Inline's Avatar
It was like burning rubber; got really old after few first times to play with it. Just found myself always leaving it to D, and found it annoying at normal traffic to navigate between P-R-N-D, versus conventional shifter.
Old Sep 10, 2021 | 05:35 PM
danktx's Avatar
While it is not the cup of tea expressed here. I have a B&M Quicksilver shifter in my '67 hooked to a 700R4. My factory shifter was crap and was for a 2 speed, I wanted a 4 speed shifter. The B&M shifter fits and works well in my console. The throw of the shifter works within the slot in the console without modification. It has switches for neutral safety and reverse lights, that didn't work with the factory shifter, though I wired them to relays for those functions because the switches are small. I must admit the way it functions wasn't what I expected but the only drawback is the wife doesn't drive the car because she doesn't like the shifter, that may or may not be a negative.
Old Sep 11, 2021 | 06:56 AM
For anyone else in this situation, be aware that ShiftWorks has the parts to convert a factory shifter to more gear operation:
2 speed to 3 or 4 speed,
3 speed to 4 speed,
Dual Gate to 4 speed.
https://shiftworks.com/collections/conversion-kits/1967-72-cutlass
Old Sep 16, 2021 | 07:03 PM
gs72's Avatar
72Cutlass S
So does Dan Janes and his conversion is a slap shifter option.
Old Sep 17, 2021 | 10:46 AM
72 Olds CS
That looks good danktx a sight lot better IMO than a b n m megashifter bolted to the floor w the column shifter still inplace!!!
Old Oct 1, 2021 | 12:37 PM
Dan Janes's Avatar
This is how my True Slap conversion for the factory floor shifter works. I also have the same features with a 4 speed detent for those changing to overdrives. Changing a 2 speed shifter to a True Slap 3 speed or a 4 speed is simple and much more affordable than a new shifter.
Dan
573-248-1389
Old Oct 1, 2021 | 12:57 PM
I wasn't very clear with my post. Dan makes a detent plate to convert a factory shifter to a 3 or 4 speed slap shifter function.
Shiftworks sells all of the "other" parts to make a "more gears" conversion look factory.
So if you want a slap shifter, use a Shiftworks indicator lens along with Dan's slap shifter detent plate and you have a completely factory looking "more gears" setup.
The Bug Man
Oct 5, 2012 07:39 AM
bobfo1
Aug 8, 2012 02:52 PM
budgdawg
May 25, 2011 06:56 AM
war eagle
May 16, 2011 01:39 PM
gabes455olds
Mar 27, 2008 08:00 AM
