Dearborn 3 speed - Ford toplaoder - Hurst Shifter
Old Oct 18, 2024 | 12:57 PM
Mhollida's Avatar
Recently purchased 1968 cutlass 350 / 3speed with console.
Researching I see that this is the ford supplied 3spd toplaoder aka "Dearborn 3.03" made for GM.
Seems this is a very solid trans, durable etc. Problem is the shifter, It is OEM Hurst 3 speed shifter 10-7A2
I got stuck in 1st gear so I pulled the shifter, redid the rods, bushings etc. and re centered the neutral position.
Mine is worn out, very sloppy etc. I removed and cleaned, lubed best I could. Searched all over but no luck finding anything new to replace other than maybe the Hurst universal 3 speed that you have to adapt for your application. (Looks kind of cheap anyways)
Checked with the Shifterdoc.com (Hurst Shifter rebuilds) he doesn't do 3 speeds.
Any ideas on shifter?
So now I'm thinking maybe long term convert to 4 speed muncie, or modern 5-6 speed trans.
Would rather do modern trans but seems like would be pricey and lot of pitfalls?
Any recommended kit suppliers for modern 5-6 speed kits, keep shifter same location etc?
Thanks for the help
Old Oct 18, 2024 | 01:27 PM
66-3X2 442's Avatar
Thanks for the help
Contact Dennis Maroudas dba DME and he can rebuild your shifter like new. His contact info is 606-237-6648 Tell him Mike Richards sent you. You will not be disappointed with his work.
FYI, if you bought a 3speed 442 in 65-69 you got the Phord trans and if you bought a Cutlass with a 3 speed floor mounted shift you also got the Phord trans. If you bought a 3 speed column shift Cutlass you the Saginaw 3 speed.
Old Oct 18, 2024 | 01:35 PM
Mhollida's Avatar
Thanks!
Yes mine is floor shift with Console.
Old Oct 19, 2024 | 06:22 AM
The Dearborn floor shifted three speed trans was standard equipment in the 442 from 1967 through 1969. It first became available as RPO M14 in Feb 1965, but the column shifted three speed manual was the base equipment trans in 65-66. For the 1970 model year Olds replaced the Phord trans with the new HD Muncie three speed in the A-body cars, but the Phord was used with column shift as the base equipment trans in the B-body line through the 1971 model year. You can probably count the number of 1971 Delta 88s built with that trans on the fingers of one hand.
From a rarity standpoint, I would hesitate to replace the three speed. As Mike noted, there are people who will rebuild the shifter, and the gear ratios in the trans are surprisingly well selected. Note that the Phord transmissions for GM applications used a Ford case but a GM input shaft, so they are pretty rare.
Old Oct 19, 2024 | 02:57 PM
davek1661's Avatar
And with a 3 speed, you shift 25% less often than with a 4 speed- so there's that going for it, too.
Old Oct 19, 2024 | 05:21 PM
Rallye469's Avatar
Can you imagine a 3 on the tree 442?
And I always wondered how a M14 stacked up against and M21 on the strip.
Old Oct 19, 2024 | 05:34 PM
66-3X2 442's Avatar
Yep, had one and it's now in Curt Anderson's care. 66 442 3 on the tree Phord unit. I think the code is M13. It was discontinued after 66.
Old Oct 19, 2024 | 06:35 PM
Mhollida's Avatar
Thanks all, If I can get the shifter rebuild and get rid of the mushy shifting I will probably keep the 3 speed.
Even if I did change to TKX or something will keep the original.
Old Oct 20, 2024 | 10:38 AM
crossboss's Avatar
Past owned:
Joe,
What is the difference between the 3 speed Top Loader input shaft for a GM vs a Ford input? Since I have never seen/used one just curious.
Old Oct 20, 2024 | 10:53 AM
Originally Posted by crossboss
Joe,
Different length and spline count. The length is the real issue, since that changes the bellhousing depth.
Old Oct 20, 2024 | 02:59 PM
66-3X2 442's Avatar
The Phord bearing retainer is also different. It will not fit a GM bellhousing nor will they interchange. I know you know this but I just wanted to show you how much I know.
Old Oct 20, 2024 | 03:01 PM
Nailed it.
RAG
Sep 16, 2024 05:42 AM
Sep 29, 2019 08:14 PM
Texas_Muscle
Jul 8, 2011 03:08 PM
MN71W30
Aug 5, 2009 05:39 AM
agtw31
Jul 21, 2009 06:00 PM
