New guy with M21 shifter question
Old Apr 21, 2026 | 11:43 AM
Cayman1's Avatar
As new guy on the block, hello to everyone. New to forum and new to 442 ownership.
I recently purchased a 1965 442 with M21 4 speed. The shifter is worn out and needs rebuilding. Hopeing someone has been down this road before and has recommendations.
Old Apr 21, 2026 | 12:05 PM
66-3X2 442's Avatar
That 65 shifter is a Muncie unit and is not a good shifter to begin with. All of the 64/65 guys I know swap it out for a 66 up Hurst Competition Plus OEM unit. You can still use your 65 handle with the Hurst unit by using an adapter that's available. I have some of the 66 up Hurst shifters complete with everything needed to install if you decide to upgrade to a much better shifter. Contact me @ pchopesq@aol.com
Old Apr 21, 2026 | 12:38 PM
Cayman1's Avatar
I tried a Competition Plus but it wouldn't fit. Hit the transmission mount. Same Hurst number for 65 and 66. That's the one everyone says fits. I'm officially puzzled.
Old Apr 21, 2026 | 01:23 PM
VC455's Avatar
Barely Registered
Old Apr 21, 2026 | 03:34 PM
66-3X2 442's Avatar
That's odd. I know of several 64/65 cars with the later OEM Hurst shifter. Do you have a picture of the Hurst shifter and mounting plate>? I talked a buddy today and he has a 65 and his has the Hurst shifter and he thought it came in the car from the factory. Mounting plates make a lot of difference & if you have the wrong one it can be the issue.
Old Apr 21, 2026 | 04:19 PM
Bfg's Avatar
Bfg
I have a 65 442 and did the swap to a Hurst shifter and didn’t have any problems hitting the mount, the adapter will make the handle higher than the stock Muncie shifter
Old Apr 22, 2026 | 04:23 AM
fleming442's Avatar
Probably hit the wrong holes in the plate.
Old Apr 22, 2026 | 05:24 AM
Cayman1's Avatar
Actually I think I figured it out. Didn’t see mounting bracket with the other items in the installation kit and with no instructions with it at all, I was trying to mount shifter to transmission, not bracket. Obviously won’t fit. Didn’t see a bracket so don’t know if it wasn’t in the kit or got shoved under something. I’ll get to work on the car again tomorrow and will look for a bracket.
Thanks to all who helped.
65B01Delta
Oct 25, 2024 07:46 PM
oddball
Sep 19, 2015 07:56 AM
BeenThere
Dec 30, 2014 02:57 PM
fiona72
Drivetrain/Differentials
Sep 15, 2010 10:48 AM
