455 flex plate
Old Dec 22, 2022 | 01:52 PM
Gene kerr's Avatar
455 flex plate
I have a 1970 442 with a pioneer flex plate and it looks like it is bowed in the center and my stock one looks flat is this normal or should i buy a different brand flex plate
Old Dec 22, 2022 | 05:44 PM
nicks1966's Avatar
Had the same problem, junk it. Mine was so bowed it left no converter end play. Mine also had the ring gear welded on , off center and crooked to make it run true.
Old Dec 22, 2022 | 06:31 PM
Gene kerr's Avatar
what brand did you replace it with
Old Dec 22, 2022 | 08:08 PM
nicks1966's Avatar
I had a pioneer on another motor that was good ,so I used that.
Old Dec 22, 2022 | 08:40 PM
Gene kerr's Avatar
pioneer
Old Dec 25, 2022 | 02:14 PM
70sgeek's Avatar
'72 Cutlass ragtop
ATI makes a good Oldsmobile V8 piece - I haver one on my 350 -
ATI SFI Approved Flexplate Oldsmobile V8
Part Number: 085-915565
Old Dec 26, 2022 | 10:07 AM
Funkwagon455's Avatar
I’ve never needed to buy an aftermarket flexplate for my cars. I’ve always been able to source factory pieces if there was damage (which is not common). I think I’ve got three known good spares and I really don’t consider myself a hoarder. Am I just in a minority and buying aftermarket flexplates is common place now? Even so, the quality control of the aftermarket pieces must be non existent based on reports.
Old Dec 26, 2022 | 11:39 AM
70sgeek's Avatar
'72 Cutlass ragtop
I dunno what reports you're basing your thoughts on but at least in regards to the ATI, it's a good quality aftermarket piece. Been behind my motor for 5+ years and was a perfect fit/function install right from the box. AND it's a bit cheaper now at $227 than I paid then ($250-ish).
Old Dec 26, 2022 | 12:32 PM
No man, you’re misunderstanding. My response was intended for the OP’s part.
Old Dec 26, 2022 | 02:47 PM
I've had good luck with aftermarket flex plates. Flexplates sometimes can be a bit not flat, it usually is not an issue unless there is interference.
edzolz
Oct 29, 2018 07:12 AM
smietana
Aug 3, 2014 12:01 PM
72Burning$$
Mar 28, 2014 04:43 PM
Stevec
Nov 9, 2012 04:45 AM
oldssragtop
Nov 21, 2006 05:46 PM
