Throttle valve 54 88
Old Aug 17, 2021 | 04:56 PM
hotrod5131's Avatar
This trans has flared on shifts since I’ve owned it but I haven’t driven it much. Today I decided to check and adjust the lineage through the process I discovered the throttle lever has about a half inch of throw. So I can only open the throttle about half way. Unhook the rod to the TV lever and everything works perfect linkage wise. I’m sure there is a problem with the internal linkage or the valve it’s self. Either way I assume this is my flare problem. How much throw should the lever have? Also any advise once I get the cover off?
Old Aug 18, 2021 | 07:05 AM
coldwar's Avatar
"Flaring" on shifts means simply bands need the adjustment procedure. This is a matter of maintenance, the procedure is in a service manual. if you don't care to buy the tools you can rent or maybe borrow them. yes get the linkage adjusted and operating correctly for travel and limits. Fluid age and condition might make you think about new fluid as well. Good luck ~
drjaredshelton
Feb 11, 2021 01:55 PM
Olds Scott
Dec 18, 2016 04:06 PM
lemoldsnut
Sep 24, 2014 03:30 AM
russell-t
Jun 19, 2012 05:48 AM
oldolds51
Jun 3, 2010 08:01 PM
