Driveshaft only slides in 3/4 inch on TH350
Old Feb 27, 2022 | 02:15 PM
yeahbuddy's Avatar
Connecting the driveshaft that was in the trunk of a 72 Cutlass. Car was filthy covered in dirt. Cleaned the yoke and the exposed shaft up to the seal but the yoke only goes in up to the seal.
I am assuming there is dirt causing it to not on any further but how would I clean the tailshaft grooves without removing It? Do I need to remove the seal and spray it down with brake clean? Trying to get it together asap so I can move it. Any suggestions welcome.
Old Feb 27, 2022 | 02:35 PM
Put a light coating of transmission fluid on the yoke and the seal. Then see if you can pop it past the seal. This is assuming you have the right yoke for the transmission.
Old Feb 27, 2022 | 03:04 PM
yeahbuddy's Avatar
What am I doing wrong here. I may have the wrong yoke as the car was a 350 car and it came with the 455 not hooked up. Driveshaft yoke has same pattern teeth but there is a large keyway between the teeth which I am not seeing on the transmission. Wrong yoke or something else?
Old Feb 27, 2022 | 05:00 PM
From the look of that yoke in the video, I'm guessing there's rust or crud inside the splines.
Old Feb 27, 2022 | 06:04 PM
OldsRacer_68's Avatar
Depending on the year of the transmission some had a yoke seal sleeve that the yoke would slide into the tail housing and then slide into the yoke seal sleeve.
Old Feb 27, 2022 | 09:31 PM
yeahbuddy's Avatar
2 hours later I was able to remove all the rounded bolts that hold on the housing. Will clean both the shaft and the yoke thoroughly tomorrow and give it another shot. Thanks for the replies.
Old Mar 1, 2022 | 08:17 PM
yeahbuddy's Avatar
You guys are right as usual. Cleaned the shaft and yoke teeth with PB Blaster and a wire brush and it slipped on smooth after. Thanks.
Patmcg59
Sep 19, 2021 07:39 PM
tgilligan
Drivetrain/Differentials
Aug 6, 2020 05:33 AM
rick442
Mar 6, 2019 05:22 AM
tgilligan
Sep 24, 2017 06:04 AM
craftsmen22
Jul 30, 2014 05:47 AM
