Solenoid 400 turbo 1971 442
Old Apr 30, 2025 | 04:48 PM
Yagottabkiddin's Avatar
I sourced a new down shift switch that mounts to the accelerator pedal and looking for the solenoid thats mounted on the transmission.
Fasick says it's discontinued
Anyone have a source
Old May 2, 2025 | 02:16 PM
No clue if anyone makes a replacement. Any transmission shop should be able to locate one. They are very easy to test.
Find the tiny orifice in the mounting face. Use a rubber tipped blow gun, apply 80-90psi of air, there should be no leaks. Now use a battery charger, power supply, jumper wires, whatever, ground the solenoid mounting surface, apply 22 volts to the wire, apply air again to the orifice. Now there should be huge are leak, remove the power, the leak should immediately seal.
not much too it.
Old May 2, 2025 | 02:52 PM
Thanks for your help 👍
Old May 2, 2025 | 03:08 PM
OLDSter Ralph's Avatar
You might want to check with these guys....
https://www.fatsco.net/?gad_source=1...SAAEgL_s_D_BwE
Old May 2, 2025 | 03:33 PM
Thank you sir
keyboard
Oct 31, 2024 06:42 PM
Feb 12, 2019 12:12 PM
92banana
Apr 3, 2017 08:40 PM
BeenThere
Oct 31, 2015 06:18 AM
turnpike_cruiser
Jun 25, 2010 12:31 PM
