63 caddy jetaway issues
Old Oct 4, 2021 | 01:33 AM
Daryljb's Avatar
Hi
I have just rebuilt a jetaway trans
Before rebuild car would not move at all
now after rebuild goes into and drives in reverse perfect.
however i have first gear perfect but no up shifts at all
no noises or vibration
and I have oil coming out of the breather
I haven’t done a oil pressure check yet (making a tester now )
any help would be appreciated cheers Daryl B
Old Oct 4, 2021 | 05:06 AM
Sounds like the modulator is not hooked up to manifold vacuum or it's defective for the no upshift issue and you overfilled the transmission. Did you check the fluid level with the engine running?
Old Oct 4, 2021 | 05:50 AM
rocketraider's Avatar
Oldsdruid
These 4-speed HydraMatics don't have modulators. My HydraMatic stuff is packed up. If coldwar or d2willys see this they'll have some insight.
Old Oct 4, 2021 | 06:10 AM
@coldwar @d2_willys ?
Old Oct 4, 2021 | 07:24 AM
Sorry, I thought it was the later 2 speed.
Old Oct 4, 2021 | 11:15 AM
Daryljb's Avatar
Originally Posted by Daryljb
Hi
Hi it has a tv rod not a modulator cheers
oil level correct
Old Oct 6, 2021 | 12:52 PM
d2_willys's Avatar
The upshift for 1st to 2nd problem can be due to a few things:
1) 1-2 shift valve is stuck
2) 2nd fluid coupling is not filling (Coupling valve is stuck)
3) G-1 section of governor is not working.
4) TV rod adjustment could also make the transmission "hunt" for the next gear if the rod is adjusted too short.
But since you have oil coming out of the breather, it sounds as if some sort of aeration is going on. I would check the main line pressure in different ranges. Should be the highest in reverse.
I would recheck the oil level first with the car running and in neutral or Park.
Old Oct 6, 2021 | 01:36 PM
Daryljb's Avatar
Thanks I’ll working on the car Friday afternoon,
I have made up a pressure gauge .
thanks for your help cheers Daryl
Old Oct 8, 2021 | 02:12 AM
Daryljb's Avatar
Hi All ,
thanks for all the input ,
I was back at the car today and did pressure check and it was down on pressure in drive .
Perfect in reverse
I removed extension housing to inspect Governor
and found my problem.
I had not tighten the two bolts that hold the cover on the governor. Absolutely disappointed in myself .
re installed and trans shifted perfectly.
once again thank for all the input
cheers and thanks Daryl B (Australia)
barbiekiddo
Dec 9, 2016 05:25 AM
RayJ
Sep 12, 2012 04:44 PM
RayJ
Sep 4, 2012 12:50 PM
RayJ
Tech Editor's Desk
Aug 30, 2012 06:08 AM
Bill
Mar 2, 2009 12:00 PM
