Chattering Clutch
Old Feb 28, 2024 | 08:13 AM
george@BWR's Avatar
Chattering Clutch
I have a 1972 Oldsmobile Cutlass Supreme with a Rocket 350 and a Muncie transmission with a 4 speed Hurst shifter. After driving the car long enough to get it fully warmed up I get a chatter in the clutch only when in reverse. Does anyone know what may cause this and how to fix it. I have had a new clutch kit installed but that did not help.
Old Feb 28, 2024 | 10:06 AM
Oldsmaniac's Avatar
from time to time the flywheel needs to be resurfaced.
Old Feb 28, 2024 | 11:29 AM
Sugar Bear's Avatar
Does the car have a limited slip differential? Backing up in a nearly straight line? Is this occurring while the clutch is fully engaged OR when it is being engaged?
Old Feb 28, 2024 | 11:36 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Not resurfacing a flywheel is like replacing brake pads and using the old worn rotor surface. Its a gamble and never recommended.
Check out this info:
https://www.google.com/search?client...5NoPiO2Q4Ac_28
http://farmmachinerydigest.com/groun...ng-a-flywheel/
Old Feb 28, 2024 | 12:22 PM
george@BWR's Avatar
The car does not have limited slip. It happens backing in a straight line when clutch is being engaged
Old Feb 28, 2024 | 12:54 PM
Sugar Bear's Avatar
Rules out limited slip clutch chatter. Was the flywheel resurfaced during the clutch replacement? Motor mounts good, particularly the right side?
Old Mar 1, 2024 | 12:45 PM
Cosmic Charlie's Avatar
I read somewhere that the M20 4 Speed with the 3.08 rear end was **** to reverse chatter while engaging ...
My does - so I work around it with decent results (just a little extra slip to get the car moving then back off and then fully engage +-) lol your results may vary
Old Mar 1, 2024 | 01:38 PM
george@BWR's Avatar
Thanks! Does this ever happen in first gear? Seems it only happens in reverse for me.
Old Mar 1, 2024 | 02:46 PM
Just reverse for me
Old Mar 1, 2024 | 05:25 PM
fleming442's Avatar
I'll throw my 2 cent in. I'm going with a high gear ratio problem and as @Cosmic Charlie mentions, it needs more rpm and slip. I heard somewhere that reverse is similar in ratio to 2nd, but I have never looked it up nor counted teeth.
I had that problem with a Spec stage 3 sintered bronze disc and a Centerforce dual friction. I have not experienced it since switching to a McLeod twin disc RST all organic..... just some things to chew on.
Old Mar 1, 2024 | 05:44 PM
VC455's Avatar
Barely Registered
Here's what I have on Muncie reverse ratios. Reverse is a bit steeper than first gear.
1963-65:
M-20 Reverse ratio 2.64
M-21, 22 Rev ratio 2.27
1966 on:
M-20 Reverse ratio 2.59
M-21,22 no change from 63-65
Napoleon1991
Mar 20, 2017 06:50 PM
Cincinnati Rick
Aug 3, 2015 07:08 PM
z11375ss
25
May 12, 2013 07:09 PM
bummerino
Apr 27, 2010 08:55 PM
mugzilla
Sep 7, 2009 05:57 PM
