Clutch fork
Old Apr 27, 2010 | 07:38 PM
bummerino's Avatar
Clutch fork
I am using the clutch fork that came with my 66 442, but I am using a Lakewood scattershield . My problem is that the fork I have is short and would require grinding the bell housing to operate. My question is did they make different length forks, Maybe I should pull it back apart and look for a part number
Old Apr 27, 2010 | 08:55 PM
442garage's Avatar
It has been several years since I had to deal with this problem, but the Lakewood scattershield does require some modification in order for the clutch fork to work properly. Lakewood industries used to offer a universal clutch fork that was based off a chevy design, and that is what I eventually used. Major issue was having an adjustable clutch fork pivot ball that gave me enough length to allow the throw out bearing to engage the transmission shaft; I ended up with a McLeod adjustable clutch fork pivot ball #MCL16909 cost thru Summit is currently $51.95 and clutch fork is $39.95 As far as I know I'm not aware of different lengths of clutch forks but I believe Oldsmobiles were somewhat more curved than the standard universal that I previously mentioned. Anyway, good luck!
1978 Oldsmobile Omega
Aug 12, 2015 06:57 PM
chornbeck
Jan 29, 2015 08:46 AM
RandyS
Mar 11, 2013 09:41 PM
jensenracing77
Feb 27, 2012 04:58 PM
bummerino
Oct 25, 2011 08:28 AM
