Which Speedo Adapter?
Old Nov 12, 2023 | 08:38 AM
Magna86's Avatar
Alright the 66 is running and driving finally :-) but the speedometer is way off. It's running 25mph faster than I'm going based on GPS speedo app. So when I'm going 65 it says I'm going 90. The car is running a 700R4 with a green driven gear and and orange/red drive gear. 3.90 gears out back and 27" tires. Based on what I've found there are no gear combo that will work. So it looks like I need an adapter but which one do I need to slow it down and read accurately or pretty close.
Old Nov 12, 2023 | 12:22 PM
olds_freak's Avatar
You'd need to change your drive gear to the gray one which has 15 teeth compared to your red one which has 17. Then you'll need either a 43 or 44 tooth driven gear. Either of those will get you close as it's calling for a 43.65 tooth driven gear.
Minnesotajeff
Feb 4, 2019 08:58 AM
ostie13
May 14, 2016 08:05 AM
Redbud40
Jul 1, 2014 05:28 AM
tmaleck
Sep 23, 2013 01:47 PM
delta254
Drivetrain/Differentials
Oct 18, 2012 10:11 PM
