1969 442 Transmission Removal
Old Jul 22, 2024 | 01:43 PM
MPSax's Avatar
Hi,
I've looked over some forums, and I understand I need to lift the car higher than a jack would go.
Any idea just how high to get the car?
Is it better to remove the engine and transmission together? VS dropping under the car and sliding out?
TH400
Old Jul 22, 2024 | 01:52 PM
The car just has to be high enough supported on jack stands for the transmission and whatever is being used to move it out from under the car to clear. I would just pull the trans.
Old Jul 22, 2024 | 02:35 PM
If you plan to pull the engine anyway, yeah you can pull them together, but there is no need to do that if you aren't planning to. I've built a set of cribbing from 4x4s that I put under the tires to get the car high enough for easy trans removal.
Old Jul 23, 2024 | 07:45 PM
This is 8 2x12 boards screwed together. I have found these to be VERY useful., far beyond transmission removal.
Old Jul 25, 2024 | 06:15 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I mounted my 70 Cutlass on my 24" stands all the way up under the front control arms, back was a little lower. It was just high enough with the trans plate adapter on my floor jack with a 4L80E. It just barely slipped by the headers on the jack. Good luck.
ericisback
May 31, 2023 06:49 AM
scott69442
Dec 14, 2022 01:15 AM
jerrybetty5
Jun 15, 2015 03:04 PM
Aceshigh
Jan 20, 2011 04:42 AM
pops1958
Nov 23, 2010 02:35 PM
