- Governor?
- Bogging Down/Losing Power
- Bad Vibration - Transmission or Driveshaft
- 1967 olds 442 rear axle bearing still leaking ??
- Driveline geometry quest.
- What's wrong with my swap?
- '68 3-speed manual on the column
- Another BOP 8.5 help question
- 2002 Bravada 4.2 L transmission Problem
- Trans slipping at 30-40 mph
- Dual gate shifter and console placement
- Driveshaft question
- What Torque Converter To Buy??? Hughes?
- Diesel transmission
- Dual Gate Shifter Install
- Correct shifter cane for 68 442?
- 1965 98 hub driven speedometer cable removal ?
- 10 Bolt Inners 12 Bolt Differential??
- 70 Dual Gate Questions
- TH 400 dipstick needed
- 200-R4 question
- 66 Olds Cutlass needs new axles
- SHIFTER for 2 speed
- Anybody swapped 4l80 into Cutlass
- 68/69 Dual Gate Shifter
- Over drive
- Vibration noise ?
- 68 Cutlass Supreme 4 spd muncie
- What would you do?
- HELP!? What type of axles do i have?
- Floor shift hump install
- How to install new shifter slide into 1970-72 std floor shifter
- Will a chevy TH350 fit in a 74 cutlass supreme?
- TH350 olds cable from gas pedal directly to transmission
- Shift linkage adjustment
- Gears and RPM
- Trouble with my HM350 !
- Special Hydramatic Tailshaft remove and installation toolI
- differential rebuilder !!
- Leaking transmission fluid
- Changing column shift to console floor shift
- Key stuck in ignition, can't turn it back to Lock
- trans and engine block numbers
- Flex plate weight hitting torque converter mount pad
- 72 transmission issues
- Hawks Racing SFI flex plate
- Removing crossmember from a 1975
- 1979 Hurst Olds Dual Gate Shifter Installation
- Dual gate cable, none fit...wtf
- G Body Shifter Handle
- grinding clunking noise
- Throttle valve cable hook-up to carb linkage
- Help identifying transmission
- Overdrive or higher gears?
- Shifter?
- Rear axle on 66 Ninety -Eight
- shifter cable rubber seal
- Rear shaft
- 79 cutlass shifting too early, correct throttle cable bracket needed
- Speedometer gear help
- 1971 Olds Cutlass gears
- 59-60 olds hydramatic interchange with pontiac, cadillac bell swap?
- Parking brake cable/200R4
- Dual Gate Conversion
- OW W-30 transmission- valve body.
- Saginaw 4 speed
- Competition plus mounting ID
- 70' Cutlass Supreme Column Shift Problem
- 1967 442 4 speed sluggish on take off.
- 400 trans
- TH400 Re&Re with long tube headers
- Loose play in transmission shifter on the column
- trans problem
- 1997 88 4T60 E Napa filter kit
- Clutch chatter
- Will a 425 flywheel bolt to a 330
- 4 speed clutch slipping again
- 350 Transmission shifting
- TKO Tremec 5 Speed
- 455 & TH400 - High RPMs at cruising speeds
- TH-350 slipping
- Transmission issue
- Will '67 Buick 225 V6 bolt up with '61 Rotohydramatic
- Torque converter
- '64 Starfire shifter conversion
- 1970 442 Transmission VIN stamp
- Wont sit on crossmember
- Chatter under acceleration
- KZF transmission question
- Stock stall speed
- Posi gear swap
- If I swap to a 700R4, can I keep my original console shifter housing?
- 69 4 Speed Brake/Clutch Pedal Assembly
- Which speedo gear to use?
- Need advice on trans behind 455
- Ring and pinion pattern
- Tranny vacuum connection
- Transmission swap in 62 Starfire
- Found my gear ratio on 260 cutlass
- changing the speedometer
- Hydramatic Crossover for 1952 Super 88
- Trans shop/builder recomendations?
- Rear help
- Transmission Changeout
- B&M Megashifter for 1976 442
- Which Torque Converter Manufacturer do you prefer
- 1972 cutlass shift indicator link
- 67 442 missing PRNDL needle
- 67 442 automatic - shift location?
- Throwout bearing not centered...
- TH350 selector shaft available new?
- Linkage adjustment
- Ideas?? 1962 f-85 clutch
- Speed Calibration
- Dual gate shifter problems
- "O" Axle gear swap help
- '70 442 - Auto Trans Crossmember Insulators or not ??
- 72 delta auto to 4 or 5 speed swap
- Rear Differential Oil
- To anyone with a 68 or 69 cutty
- 700R4 installation
- Rear End for 65 cutlass
- 1963 cutlass speedometer cable
- After rebuild
- linkage problem?
- Tranny swap, driveshaft
- Previous owner did something to my kickdown switch -any guesses?
- Speedometer cable 200R4 to TH400 swap
- What kind of shifter is this?
- Roto-Hydramatic Rebuilders?
- OAI Foam Seal
- 70 Cutlass - TH350 Pan gasket R&R Cross member removed?
- will this fir a 68-72
- 1974 Hurst posi?
- Olds th400
- transmission tunnel
- 200r4 Conversion and gear ratio help.
- 70 driveshaft cutlass supreme
- 1970 cutlass o type rear what to do??
- 63 F-85 Tranny help needed for Germany :-)
- 1950 olds 98 w/ 1964 394
- Replacement Flywheel 1966 330 cu in
- 69 442 4 speed vibration/rattle on acceleration
- Steering Column for "E" transmission Use
- 62 starfire driveshaft
- Diff spider gear help
- 72 Cutlass 350, install manual trans
- shifter cable issue
- What RPMs at 55 MPH for 1964 w/394 and SlimJim trans?
- '65 Cutlass auto floor shift conversion
- Auto to 4-Speed Floor Hole Dimensions?
- Installing Transgo shift kit. Please help
- 4 speed speedometer gear housing
- Dual Gate Questions
- Speedometer cable seal / o ring at tranny?
- 200 4r swap speedometer
- 1966 442 Shifter Handle
- Transmission pan gasket
- Gear Vendor's overdrive
- lost drive
- Need a transmission for a 1962 dynamic 88!
- BOP T350 core value?
- 1971 Cutlass turbo 350 trans leak
- Thinking about transmission rebuild..
- Need a transmission!
- 69 Oldsmobile Stiff Clutch Pedal Solutions?
- 62 Cutlass 215ci flywheel lightening
- Gear Vendors
- Cutlass 1966 torque loss!
- Transmission crossmember and mounting bolts
- Turbo 400
- Detent Cable on 76' Cutlass
- Need info on a trans hooked to a 61 olds 371
- Transmission not engaging until hot
- Clutch problems 70 Cutlass
- 65 Jetstar Speedo Cable
- Anyone know what this is ??
- Centreforce Clutch
- 62 Culass driveshaft support for bearing
- ROTO 5 - Help
- 72 Cutlass - Hwy RPM???
- Rebuild myself or buy a rebuilt?
- Driveshaft Differences
- gear help
- 455 Flywheel and Delmont 88 4 Speed Conversion
- Hydramatic throttle valve tool
- gvod sender wire
- Couple b body diff questions
- Shift lever stuck with key in ignition
- 1963 Olds 98 trans and diff
- Knocking sound under shifter
- 56 olds transmission removal, HOW?
- Flushing the tranny cooler radiator
- Bell housing alingment
- Would this fit to my 76 Oldsmobile 98?
- California performance trans
- HELP....!!! Can you recommend a trans shop in Metropolitian Detroit
- Speedometer Gear
- Mondello Transmission
- 1964 Ninety Eight Slimjim buzz, whine, and slipping
- Chevy 3speed to 303
- delta 88 posi rear
- 56 Jetaway?
- questions on B&M transpak
- B&M Megashifter
- Manual shop torque reference typo mistake?
- transmission will not shift in drive.
- O type rear end
- Dual Gate shifter, how does it work?
- code number
- 55 olds 3 speed manual to sb chevy
- Driveshaft orientation
- Rear end gears/ full rear end swap?
- 4 Speed bellhousing paint color
- Driveshaft questions
- What Tranny Do I Have?
- transmission reseal?
- Turbo 350 Shift Problem
- leaking transmission
- 66' F-85 ten bolt axle shaft length
- Transmission Surges
- steer box
- diameter valve for gear lever
- Jetaway trans cooler hoses
- turbo 350 seals
- 1962 F85 Buzzing noise from transmission
- rear end question
- converter seated?
- 350 turbo going clank
- paint color on trans
- 72 rocket 350 tr 3650 swap
- First gen toronado reliability?
- Best street/strip tranny for 72 cutlass 350
- Vibration in the ?? - 1973 Cutlass S
- Wheel hopppppp
- Transmission options
- Olds Powered K20
- spedo cable to trany
- Ever seen one of these?
- rear coil springs
- 1968 ST300 Jetaway Trans leak
- Jet Away Shift
- Hurst shifter arm replacement 4 speed
- U-Joint Help
- New GearVendors overdrive
- torque converter aand flexplate issues?
- transmission not taking fluid
- !963 F85 rearend swap
- Transmission Yoke Help Needed Please
- Differential shop in chicago
