400 trans
Old Aug 12, 2017 | 12:20 PM
Gerald Nickels's Avatar
400 trans
If I drain the pan on a 400 stock pan how many quarts does it take with convertor full ? I have a flex tube on the 400 trans no stock tube or rod.
Old Oct 8, 2017 | 12:00 AM
OldsRacer_68's Avatar
From the Service Manual:
Approximately four quarts will be required to fill the transmission if the oil pan has been re-moved and drained at the same time that the fluid is changed.
Approximately nine quarts are required after an overhaul.
chrisneu68olds
Dec 30, 2011 10:17 AM
dgreen
Nov 6, 2011 09:40 AM
Gearhead442
Jan 27, 2011 03:03 AM
sbFALL63
Jan 23, 2011 09:01 AM
sbFALL63
May 28, 2010 05:45 AM
