1967 olds 442 rear axle bearing still leaking ??
Hi all. well looks like it showed its face again, i did post this before and really thought that by putting in a new axle seal cuz there wasn't one that the story would end there, it didn't, looked out there tonight and gear oil leaking out again from the backing plate down, well i not sure how iam even going to get that one out of there, chisel punch ?? i will rip into it this weekend it was good for like 2 weeks nothing on the floor, then i took it out last weekend and finally romped on it so it would be ready to go to rock falls on sep 22 3 days since i took it out its leaking, any ideas on what i should be looking for, really frustrating, thanks for your help, john...
Will do, i know the part # is 8594S if you look at my original post there was no seal in there that's why it leaked of course, i am suspicions right now i had nothing to compare it to, god i hope i don't have the thing in backwards ???? the rubber ring is facing outwards towards the drum i remember putting it in that way !!
Hopefully the leak was due to something simple such as the seal being installed the wrong direction.
Hi Ken !! thanks for the tip, iam going to be getting into it Friday on my day off !! i bought 2 of the seals so i still have the 1 left here, no matter what iam going to take a pic when i get it apart wether or not i did it right or wrong like you said before maybe it would help the next guy coming down the trail, thanks john..
removal
Well your not going to be able to reuse it...Just buy another. If you have a 3/4 inch socket set ...or and sleeve tubing same diameter that fits nicely you can use that to tap in the tube...The removal is easy use a drift (1/2 diameter steel rod) to mangle one side of the seal and then just pry it out through the doughnut hole center wedging against the outer tube edge. It will bend up like a potato chip.
Jim
Jim
