700R4 installation
Old Aug 26, 2016 | 05:11 PM
Big Features's Avatar
700R4 installation
Experts,
I have a 1968 442 with a TH400 (column shift). Would like to install a 700R4 and keep the factory look. Are there any kits? I'm sure I'm not the 1st person to do this. Any help is greatly appreciated.
Mike
Old Aug 27, 2016 | 05:47 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Why are you going 700R4, is it the same length as your TH400? It will need a lot of beefing up to last behind any power. The 1-2 drop is noticeable. I have ran both the 4L60E and 2004R behind Olds V8's, I prefer the 2004R, not only for gearing but ease of installation in my short tail 350 cars
Old Oct 31, 2016 | 04:54 PM
Just looking to put a 4sp auto in and keep the factory look. I'm pretty sure I'll have to go to a cable set up and cut the drive shaft.
Old Oct 31, 2016 | 06:09 PM
svnt442's Avatar
The 700R4 would require an adapter to bolt up to your engine. A 200-4R will have the correct bellhousing bolt pattern. Both will need beefing up to live with the torque of that 400 and there are plenty of parts for the 200-4R out there to make it live.
Also with the 200-4R your diveshaft is the correct length, but you'll need a yoke for a tH350 to make it work.
Old Oct 31, 2016 | 06:11 PM
svnt442's Avatar
Also the 200-4R will allow you to not have to mess with the parking brake cables because it bolts up in the same location at the TH400.
Old Nov 1, 2016 | 08:07 AM
200R4 it is..........Thanks!
TOONLOVESCHERYL
Feb 4, 2016 06:30 AM
64starfire
Jun 10, 2009 06:51 AM
projectheaven
May 18, 2009 05:20 AM
64starfire
Apr 22, 2009 01:00 PM
Jolly Green
Feb 25, 2009 07:25 AM
