Trans slipping at 30-40 mph
Old Jul 27, 2019 | 07:01 PM
jhawkthebeast's Avatar
Hey everyone I swapped my blown original th-350 on my 72 small block cutlass. I bought a tci streetrodder and the vacum modulator hose that connects from my trans to the carburetor the carberutor used to act as a vacuum but it isn’t sucking any air. So I’m thinking that’s why it won’t shift and why It’s slipping. Fluid levels and quality are good. (There’s a trace amount of that black fluid from the old trans but I will be changing the fluid again we already put 12 qts in it) any other place I could stick hook it up to? I’ve read intake manifold but I will be swapping that next week. And I’ve heard of people connecting it to the distributor. If any can help it would be much appreciated.
Old Jul 27, 2019 | 07:29 PM
You can connect the vacuum modulator line to any full/manifold vacuum port including the front of the carb. You can T into the distributor line also. Make sure the tubing is clear before hooking it up.
Old Jul 27, 2019 | 08:08 PM
The carb isn’t sucking in air and I’m getting a new manifold and carb Monday so distributor sounds like a beater option. How do I go about doing that?
Old Jul 27, 2019 | 08:21 PM
With one of these
Old Jul 27, 2019 | 08:52 PM
With one of these
so which one do I unplug? From the distributor
Old Jul 28, 2019 | 10:36 AM
So I messed around with it this morning looked all around the manifold and carb. Couldn’t find anything so I checked the distributor but there wasn’t any suction from there either.
Old Jul 28, 2019 | 01:34 PM
There are 2 ports on the carb, 1 above the throttle blades and 1 below.
Old Jul 28, 2019 | 09:15 PM
I don't see why getting a new manifold makes any difference - it's just a rubber hose that slips onto a hose barb. The intake manifold should have several threaded bosses where you can screw in a hose fitting and hook up a rubber hose.
sykosoft
Mar 30, 2018 09:43 PM
tgilligan
Oct 23, 2017 06:34 PM
llittles
Aug 13, 2017 04:59 AM
Olds1971
Jun 8, 2014 07:32 PM
jeffsfleet
Apr 11, 2013 05:13 PM
