1962 F85 Buzzing noise from transmission
Old July 31st, 2014, 07:00 AM
My62F85's Avatar
Hello,
I have had my 62 F85 for just about 2 months and I have just started hearing a load buzzing noise coming from the automatic transmission. It does not always happen but it typically happens when I shift out of park. Sometimes it will go away when I put it to a different gear then back to drive or reverse. Other times it stays buzzing until the car starts moving.
Yesterday it happened and I put it back in park and the buzzing stayed on so I was able to locate the noise as coming from the transmission. Any ideas as to what is causing this and what should be done to fix it?
Thanks.
My62F85 is offline
Old July 31st, 2014, 08:48 AM
1970-W30's Avatar
First thing I would do is check the transmission fluid level. Transmission warmed up, idling in park.
1970-W30 is offline
Old July 31st, 2014, 09:21 AM
Oldsdruid
rocketraider's Avatar
X2 on check fluid level. Roto HydraMatics are known to buzz when fluid is low. Probably pump cavitation from where it's trying to suck and pump air.
Yes the baby SlimJims were just as cantankerous as their big brothers.
rocketraider is offline
Old July 31st, 2014, 09:44 AM
My62F85's Avatar
Thank you.
The dip stick is not the correct one for this car I was told by the previous owner. It may very well be low on fluid.
My62F85 is offline
Oldscutty72
March 3rd, 2014 07:30 PM
k9ulan
March 26th, 2012 06:02 PM
CutlassLegend
October 10th, 2011 06:30 AM
fmbjogger
October 23rd, 2010 09:05 AM
ow30442
September 2nd, 2008 02:51 PM
Quick Reply: 1962 F85 Buzzing noise from transmission
