Need a transmission!
Old July 15th, 2015, 11:50 PM
eddieunderground's Avatar
My transmission went out on my 62 Dynamic. The bell housing is cracked. And pressure plates are cracked. Any suggestions where I can get a transmission or the housing? Or what can I do? Or if I can upgrade without a lot of fabrication?
eddieunderground is offline
Old July 16th, 2015, 09:46 AM
D. Yaros's Avatar
Are we talking manual tranny here?
D. Yaros is offline
Old July 16th, 2015, 10:58 AM
Oldsdruid
rocketraider's Avatar
If you're talking about the torsional damper, FATSCO transmissions should have it- they have some made every so often. Bellhousing- you talking about the adapter between engine and transmission? Used is your only option but 61-64 are the same and I won't swear one for an earlier 4-speed HMT won't work.
rocketraider is online now
coppercutlass
March 1st, 2013 07:33 AM
maskinen
April 8th, 2008 05:16 AM
78cutlass
March 12th, 2008 12:13 AM
thomaswatk
April 7th, 2007 03:41 AM
WasteOfMind00
February 24th, 2007 10:14 PM
Quick Reply: Need a transmission!
