79 cutlass shifting too early, correct throttle cable bracket needed
Old Dec 10, 2017 | 01:09 PM
Northern Custom Cruiser's Avatar
Gearhead in training
So my newest edition to the family is a79 cutlass with the 260 v8. The only real issue Im having is that the original TV cable bracket is missing an a makeshift universal one is in its place. The car is shifting from 1st to 2nd at around 10-15 and from 2nd to 3rd at around 25 but stays inbetween gears for a few seconds durring shift from 2nd to 3rd. Pressing the gas harder prolongs the time it takes inbetween gears. Im assuming this is caused by the wrong cable bracket? Help is greatly appreciated!
Old Dec 11, 2017 | 08:22 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
You need to make sure you are getting full TV pull at full throttle. Do it before you destroy the trans.
Old Dec 12, 2017 | 03:00 AM
What transmission is in your car. If its a T350, that is not a TV cable, it is a kickdown, and should be fully engaged at WOT. The shift points are controlled mostly by the governor and minutely by the modulator. The modulator, if adjustable, will move the shift point up or down a few mph.
Old Dec 12, 2017 | 10:45 AM
More than likely a TH200, hopefully it wasn't drove far without a proper bracket.
defiant1
Feb 4, 2020 08:53 PM
seok
Mar 15, 2011 10:53 AM
69oldsguy
Aug 25, 2010 07:42 AM
MJAKS462
Apr 7, 2010 03:14 PM
1k442
Dec 22, 2008 07:24 PM
