455 Flywheel and Delmont 88 4 Speed Conversion
Old Apr 7, 2015 | 04:57 PM
Delmont 88 PA's Avatar
I'm changing my 1967 Delmont 88 to a 4 speed and the flywheel has a removable weight. The flex plate that was removed also has a weight and it worked fine. Should an early 70's 455 have a weight on the flywheel? With all other things being equal, and the fact that the flex plate worked fine with a weight (and the 425 vibration damper) I'll probably put the weight on... I think.
Were the early 70's 455's internally or externally balanced?
Related--it appears that a Camaro clutch pedal will work fine next to the existing brake pedal. I'll have to trim the brake pedal bushing and will be welding a steel bushing to the Camaro clutch pedal--to give it stability since the clutch master cylinder will be a few inches to the left of the center of the clutch pedal. I'll post again if (when) this actually works.
Old Apr 7, 2015 | 07:04 PM
2blu442's Avatar
I've never seen a manual transmission flywheel with a weight. I'm used to seeing drill holes in it that can have pins placed in them to balance the flywheel. Can you post pictures of what you have?
John
bluecab
Aug 6, 2015 08:38 AM
Delmont 88 PA
Dec 3, 2014 08:01 AM
Delmont 88 PA
Drivetrain/Differentials
Aug 9, 2012 08:36 AM
Beau Dirt
Apr 28, 2012 02:21 AM
Vargen
Apr 19, 2008 03:22 PM
