Hydramatic throttle valve tool
Old March 12th, 2015, 06:27 PM
Olds Scott's Avatar
Does anyone manufacture this tool or have the specs to build it. Already have front and rear band adjustment tools and looking to complete the set.
Olds Scott is offline
Old March 12th, 2015, 09:48 PM
Ozzie's Avatar
I'm wondering exactly which tool you are referring to and which Hydramatic. Could it be for the '55 in the photo? It may be the one to align the throttle lever on the exterior of the transmission. There was at least two varieties of this one; one was a notched bent up flat metal gauge; the other was a combination flat metal and rod which entered the throttle lever hole. Both rested on the rear machined surface of the transmission.
Ozzie is offline
Old March 13th, 2015, 08:33 AM
Olds Scott's Avatar
I am looking for the one with the flat metal and rod that goes thru the throttle lever hole. That would complete my set of tools for making adjustments
Old March 13th, 2015, 04:31 PM
Ozzie's Avatar
I don't have that tool either, so I can't provide exact dimensions, but I do remember the number 6-3/4" in connection with it. Possibly it may be the length of the rod. ???????
There is one more tool used in connection with this tool. It is the throttle lever bending tool, used when the other tool determines the lever dimension to be incorrect. It can be used with the lever on the transmission. You might be able to do a "work around" on this tool. ??????? I am of the understanding that if any bending forces are transmitted to the internal control valve assembly, serious damage can occur. The bending tool has two long handles with three studs protruding from the arms near the pivot. There were at least four varieties of this tool made by Kent-Moore and New Britain. They had different applications for different Hydramatics on different cars & trucks.
Ozzie is offline
Old March 13th, 2015, 06:03 PM
Olds Scott's Avatar
Thanks Ozzie, was able to find the KM J-2029 bending tool but still need to find the KM J-5605 gauging tool. Hard to find.
Old March 13th, 2015, 07:57 PM
Ozzie's Avatar
The gauging tool is so simply made, if someone would have one and provide the dimensions it could probably be easily fabricated. If I find something I'll send the information.
Ozzie is offline
Old March 13th, 2015, 08:18 PM
Olds Scott's Avatar
Thanks Ozzie, I can do basic fabrication so any dimensions you can come up with help. I had my transmission rebuilt but would like to make sure all adjustments are zeroed in.
Old June 18th, 2015, 06:59 PM
Olds Scott's Avatar
Any luck coming up with those tool dimensions
Old June 18th, 2015, 11:22 PM
Ozzie's Avatar
Unfortunately, I have not. I also do not have that tool, and I don't know where to find one. If one of the members had one and was willing to provide the exact dimensions, we could probably fabricate it. I was hoping this thread would provide a volunteer, but apparently it didn't. All I have is the picture in the shop manual, which tells me it is fairly simple to make (if we had good dimensions); but the photo is not good enough to scale it. The length of the rod and the offset would be the crucial part. That 6-3/4" dimension got stuck in my head for something, but it's been so long that I no longer remember what it was for.
Ozzie is offline
Old June 19th, 2015, 07:59 AM
Olds Scott's Avatar
You are right about the measurement. Still would like to have diagram of tool if some has one. Getting under car to check measurements mulitiple times is hard on my back and knees.
Kaline
April 18th, 2022 03:35 PM
defiant1
February 4th, 2020 08:53 PM
billmerbach
November 9th, 2014 03:42 PM
1971viking
October 26th, 2011 05:17 PM
68Tom
November 14th, 2010 07:22 PM
Quick Reply: Hydramatic throttle valve tool
