70 driveshaft cutlass supreme
Old March 26th, 2016, 05:36 AM
Rustbucket2's Avatar
I bought a 70 cutlass , that is torn down to shell, the drive shaft that came with car looks to be two pieces, rubber inside! does this drive shaft slide inside one another? I put it in car and it slides 3 inches inside trans put just clears rear pinion , only has about 3/4 inch play to slide in and out trans! I think it should move more then that. not much room for up and down travel of rear axel.
Rustbucket2 is offline
Old March 26th, 2016, 05:58 AM
The 2 pieces of the shaft should not move. Can you post a picture of the shaft installed in the transmission.
oldcutlass is offline
Old March 26th, 2016, 12:06 PM
pics of both ends
Old March 26th, 2016, 12:56 PM
Full-time Taxpayer
Qwik71442's Avatar
Originally Posted by Rustbucket2
pics of both ends
Are the pictures with the rearend hanging down or sitting with the weight of the car on it?
Qwik71442 is online now
Old March 26th, 2016, 03:14 PM
pair of Jack stands are under rear axle , and pair under front frame.
Old March 26th, 2016, 03:47 PM
I believe the drive shaft yoke only moves .375 each way from its neutral position. It looks fine in the picture, but others can chime in.
Old March 26th, 2016, 04:06 PM
Thanks, good news to me, that's the only driveshaft I got with car. I had many GTO's and Skylarks, and they all had a lot of room for movement, I was worried . If anyone else thinks different , let me know.
tcarroll
Drivetrain/Differentials
June 26th, 2012 04:13 PM
Mike H.
November 28th, 2011 11:31 AM
TRW
January 21st, 2011 05:38 AM
esisson
April 1st, 2009 08:30 AM
Quick Reply: 70 driveshaft cutlass supreme
