Driveshaft question
Old Jun 20, 2019 | 07:50 PM
billrob71's Avatar
Driveshaft question
Hello all have a driveshaft question ,
When I purchased my car I knew it had the incorrect rear in it and knew it would be changed and have the correct one installed.
This is what I have 71 / 72 10 bolt rear diff part number 1235197 , bolt in axle axles
I have the correct 70 12 bolt o type rear diff part number 402227
The nose of the 12 bolt is a inch shorter then the 10 bolt
checked the u joint and fits both differentials correctly just need to change the strap
my driveshaft from end of the u joint to end of the u joint is little over 55 3/4 long , the yoke is 6 1/4 inches
long , and has 2 inches that is actually in the end of the transmission
I’m calculating I’m gonna be a inch shy and should change the yoke anyone ever ran into his before and can direct me to where I can get a longer yoke.
Thanks for any help
Old Jun 20, 2019 | 08:01 PM
RetroRanger's Avatar
72 Olds CS
not sure but you may need a longer DS
your user name suggests a 1971 , but your post suggest a 1970. if you state what car your working on it will help
Old Jun 20, 2019 | 08:07 PM
billrob71's Avatar
I have a 70 442 the rear that came in the car is out of a 71 or 72 I have the correct 70 12 bolt for the car.
My user name is part of my first name and last name and birth year 😉
Old Jun 21, 2019 | 02:14 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Depends on which style of yoke you have. With the car level how much of the machined surface is between the trans seal and unmachined yoke?
Are the inner splines all the way out to the end of about half way?
Give this guy a call for exact info. There is a measurement guide to the left on the home page.
https://www.dennysdriveshaft.com/
David DeCan
Drivetrain/Differentials
Nov 3, 2016 09:30 AM
Bozang1
Apr 21, 2016 08:54 AM
texasred
Apr 27, 2012 07:28 PM
smcurro
Mar 1, 2009 05:50 PM
don71
Apr 19, 2008 03:30 PM
