72 Cutlass 350, install manual trans
Old Nov 19, 2015 | 11:04 AM
hoodooman's Avatar
Hi Guys,
I'm looking at purchasing a 72 cutlass with a rebuilt olds 350 and a blown auto trans. I have absolutely zero interest in installing another automatic. I've never understood why anyone would want an automatic behind a fun "drivers" car! I want to install a manual trans hopefully without breaking the bank.
When this engine was rebuilt, a new crank was installed that is already drilled for a pilot bearing.
questions:
- Is the olds 350 engine bolt pattern different from a chevy 350?
- I think I heard that the olds bellhousing (specifically where the trans mounts to) is different than a chevy bell housing?
I know I'll need the clutch pedal assembly and either a zbar with mechanical linkage or a hydraulic setup of some kind.
I'd like to get a used muncie, saginaw, t10, or something similar instead of purchasing a brand new $2400 tko 600.
- how easy is it to find one of these transmissions that will bolt up to an olds bellhousing? do i need an olds-specific trans? is there such a thing?
I appreciate any input, I've only ever had a nova before, and those are super easy to find parts for.
What would you guys do here without totally breaking the bank?
Old Nov 19, 2015 | 11:10 AM
Qwik71442's Avatar
Full-time Taxpayer
may be worth considering
http://www.jegs.com/p/McLeod/McLeod-...51132/10002/-1
Old Nov 19, 2015 | 02:02 PM
RetroRanger's Avatar
72 Olds CS
yes BOP and chevy bellhousing bolt patterns are different. any muncie saginaw will bolt to the BOP bellhousing
Old Nov 21, 2015 | 07:22 AM
These are automatics but the bolt patterns are the same on the MT bellhousing. LH is Chevy, RH is all other GM V8s.
When you buy a bellhousing, be SURE to get one that has the dual starter notch. There are some BOP bellhousings that only have the starter notch on the passenger side. These are Buick-only. Olds and Pontiac have the starter on the driver's side and need a notch there also.
RALLYE KID
Feb 1, 2015 12:22 PM
Aug 3, 2013 08:10 AM
shamusj
Jun 11, 2013 10:47 AM
dharlett
Sep 23, 2009 03:30 PM
