Torque converter
Torque converter
Hi there I would like to upgrade the torque converter on my 1969 Oldsmobile delta 88, 455 engine , the car engine is stock but i guess I would like for it to go a little faster, faster take off, it Is very decent now being stock but a little bit more juice will be nice, currently have dual exhaust super 10 flowmaster, with the Thornton s w exhaust manifolds, 455 torker intake manifold, edelbrock carburetor 1407 750 CFM, HEI distributor, which torque converter do you guys recommend, I believe this cars have the th375 transmission does a th 400 torque convert fit? Any help will be appreciated thank you
Build ticket would indicate. Others on here may chime in with what that model of car typically came from the factory with.
Is it a one wheel burner when you get it to spin out?
If you do rear end gear, may look at limited slip as well.
GINCSC
Dec 19, 2015 01:49 PM
