Torque converter
Old Jun 24, 2017 | 01:44 PM
simpleold's Avatar
Torque converter
Hi there I would like to upgrade the torque converter on my 1969 Oldsmobile delta 88, 455 engine , the car engine is stock but i guess I would like for it to go a little faster, faster take off, it Is very decent now being stock but a little bit more juice will be nice, currently have dual exhaust super 10 flowmaster, with the Thornton s w exhaust manifolds, 455 torker intake manifold, edelbrock carburetor 1407 750 CFM, HEI distributor, which torque converter do you guys recommend, I believe this cars have the th375 transmission does a th 400 torque convert fit? Any help will be appreciated thank you
Old Jun 24, 2017 | 05:18 PM
gs72's Avatar
72Cutlass S
You don't mention your gear ratio. Changing rear end gearing may be a better choice if you are running a high ratio gear set.
Old Jul 1, 2017 | 06:20 PM
simpleold's Avatar
Sorry not very sure about that car is very stock but I don't know exactly gear ratio how would I know?
Old Jul 3, 2017 | 05:51 AM
442fanatic's Avatar
Build ticket would indicate. Others on here may chime in with what that model of car typically came from the factory with.
Is it a one wheel burner when you get it to spin out?
If you do rear end gear, may look at limited slip as well.
Stevec
Apr 20, 2012 05:46 AM
Fred H
Jan 24, 2008 07:58 PM
SPEEDROCKET
Dec 18, 2007 06:35 PM
Surfrat67
May 14, 2006 03:42 PM
