Jetaway trans cooler hoses
Old Aug 5, 2014 | 02:37 AM
lazy394's Avatar
Any help here would be great. My 59 98 jetaway blew the flexible hose from the trans to the 3/8 steel tube that goes to the radiator.
After 2 days I have not been able to locate any fittings to make a new one, Anyone got any leads?
Cheers
Scott
Old Aug 5, 2014 | 05:01 AM
5998DownUnder's Avatar
Talking
Hi Lazy,
In my parts cattledog: (Master parts list)
'1956 thru 1959 Model "O" H.T......HOSE, cooler pipe to adaptor..2 574300.......'
(2 being 2 x off and 574300 being part number).
I'm sure if you go to your local Supercrap Auto, the work experience chick will drag one or two off the shelf for you.
But say on the off chance they are out of stock, take a sample to a brake and clutch place. They have all sorts of weird connections and can put the connectors on the hose using that special crimping thing they do for pressure hose connections.
I've done this for my truck.
5998.
Old Aug 5, 2014 | 07:22 AM
You might also consider a hydraulic shop. Bring your hose with fittings and they can almost build a hose for anything.
Old Aug 5, 2014 | 07:27 AM
59-59-59's Avatar
These can be found new from Fusick
Old Aug 5, 2014 | 04:00 PM
lazy394's Avatar
Thanks heaps for the tips, got the Enzed guy out only to find the ends are not available. I have ordered a new one from Fusick .
Scott
Old Aug 5, 2014 | 04:06 PM
lazy394's Avatar
Smile
Originally Posted by 5998DownUnder
Hi Lazy,
5998.
Cheers for the help
Old Aug 5, 2014 | 04:37 PM
Just out of curiosity, did Fusick use the original part number at all?
When I get my recoed engine shipped in, and while I am changing over engines, I will give the gearbox a freshen up with new gaskets, seals, etc.
You have just given me an idea for something else to change out while the gearbox is out.
Old Aug 6, 2014 | 02:01 AM
lazy394's Avatar
It is a mongrel to get at in the car, so do it while they are out. Fusick Part number 4300, $16.50 each.
78ChevOlds
Aug 27, 2010 10:31 AM
meoff
19
Oct 28, 2009 02:20 AM
sshriber
Feb 27, 2009 12:07 PM
68conv455
Jan 3, 2009 11:53 AM
bjtstarfire
Dec 13, 2008 08:48 PM
