Diff spider gear help
Old Jan 12, 2016 | 01:18 PM
sammy's Avatar
Sammy70 455 Supreme
Took the axles ot of 1985 442 aand one of the differential spider gears fell out...no idea how. HOW do you put it back in when both axles are turning opposite directions? ARRGH.....any help is greatly appreciated...
Old Jan 12, 2016 | 03:51 PM
Mmm, yeah, you have to get it started so that when you turn the gears the spider moves into the correct position. It shouldn't be difficult - it fell out easily, right?
Old Jan 12, 2016 | 05:37 PM
sammy's Avatar
Sammy70 455 Supreme
Yes, it fell out easily....should I be taking the other ring gear out?....oops, I meant to say spider...good catch
Old Jan 12, 2016 | 06:35 PM
Octania's Avatar
ring gear? Hell no, if that spider fell out it can fall back in.
you do have to get both out or almost out, then start it [them] in, then turn one axle to "walk" the little gears in place at the same time.
Why was the spider gear shaft removed? Is this one of them type C designs?
Old Jan 12, 2016 | 07:34 PM
sammy's Avatar
Sammy70 455 Supreme
I pulled the axle to replace the backing plates.....and yes two c clips
Old Jan 13, 2016 | 10:48 AM
sammy's Avatar
Sammy70 455 Supreme
Got it back in ....I was trying to put it in with the other spider gear in...ty for the help
66 Olznut
Nov 5, 2013 03:53 AM
smietana
Nov 3, 2013 12:07 PM
442garage
Aug 9, 2013 07:13 AM
goatwgn
Drivetrain/Differentials
Dec 28, 2012 08:28 AM
Bluemeanie
Non-Olds Engines
May 3, 2012 04:06 PM
