Trouble with my HM350 !
Hello !
This afternoon I replaced the radiator on my 1973 delta 88 . No problem, but when I finished, and tried to drive, the transmission doesn't work anymore ! When I put Reverse, or Drive, nothing happen.
What Can it be ? I'm a little worried... Thank you !
Yes. You always lose some when replacing a radiator. Run it in park until the car is warmed up to operating temp.
In park at idle, check the fluid on the stick. You'll need to wipe it once, then re-insert to get the correct reading.
Thank you, it works ! I had ni idea a lack of fluid make the transmission completely stop working. Is it a security ?
Anyway, I just start the restauration of the car, I think it will not be the last question I will ask here ^^ Thanks a lot !
gardizzle
August 27th, 2012 09:20 AM
