Ive been a bit bored and itching to restore or fix something lately so I looked up in my garage one day and saw this dual gate shifter on a shelf. I kind of knew what had to be done and visualized what I needed to do to it and I had all the parts and tools to do so why not? This will be for another project I have down the road that I will share with you guys when the time comes. A little dated but complete Started disassembly Was thinking of removing shifter to have it rechromed but I think it will clean up good enough After some cleaning and polishing Shifter linkage rubbed a groove on frame body
Sandblasted area in prep for weld bead Filled groove with weld Re formed to original shape
I started with a rusty but mostly complete unit. This is where I'm at today after a couple weeks in my spare time.
Bead blasted some parts I didnt bead blast the top plate because I wanted to try to preserve the color. Mostly everything is bare steel except for top plate and a few pcs. I decided to chemically remove rust from top plate on shifter body in order to save the color. Wire wheel after blasting brings out the shine. Original light socket Bead blasted Etch primed Gloss white paint Slowly cleaning each pc Removing rust from small pcs that I want to preserve finish color on (black oxide) Rust chemically removed from top plate Dipped top plate in black oxide solution Preparing for re-assembly I wire wheeled and brushed what I could on the main body and went over with SEM satin clear clear coat for protection Satin clear on main body I used matte finish clear for top plate
