1970-72 Dual gate shifter refresh
Old Sep 23, 2024 | 06:42 PM
scrappie's Avatar
Ive been a bit bored and itching to restore or fix something lately so I looked up in my garage one day and saw this dual gate shifter on a shelf. I kind of knew what had to be done and visualized what I needed to do to it and I had all the parts and tools to do so why not? This will be for another project I have down the road that I will share with you guys when the time comes.
A little dated but complete
Started disassembly
Was thinking of removing shifter to have it rechromed but I think it will clean up good enough
After some cleaning and polishing
Shifter linkage rubbed a groove on frame body
Sandblasted area in prep for weld bead
Filled groove with weld
Re formed to original shape
I started with a rusty but mostly complete unit. This is where I'm at today after a couple weeks in my spare time.
Old Sep 23, 2024 | 07:04 PM
scrappie's Avatar
more work on the dual gate
Bead blasted some parts
I didnt bead blast the top plate because I wanted to try to preserve the color. Mostly everything is bare steel except for top plate and a few pcs.
I decided to chemically remove rust from top plate on shifter body in order to save the color.
Wire wheel after blasting brings out the shine.
Original light socket
Bead blasted
Etch primed
Gloss white paint
Slowly cleaning each pc
Removing rust from small pcs that I want to preserve finish color on (black oxide)
Rust chemically removed from top plate
Dipped top plate in black oxide solution
Preparing for re-assembly
I wire wheeled and brushed what I could on the main body and went over with SEM satin clear
clear coat for protection
Satin clear on main body
I used matte finish clear for top plate
Old Sep 24, 2024 | 04:15 PM
scrappie's Avatar
All back together
I got the shifter back together today, now I'll just put it back on the shelf and wait for the next project to begin.
BeenThere
Dec 19, 2024 10:40 AM
BeenThere
May 30, 2024 03:45 AM
tkcutlass
Oct 3, 2022 06:09 PM
69442murph
Mar 27, 2022 06:20 AM
